1992 Accord will not start
My 92 Accord will start and die. I then have to wait several minutes before I try start it again. I don't do it all the time. It seems to happen when you are pressed for time. Am I jinxed or is other Accord owners having the same problem. I had a complete tune-up and timing job. I say about a month or so ago. My D4 light is flashing also.b
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omrider »</TD></TR><TR><TD CLASS="quote">may the alternator or fuel pump is about to die
i have a 92 and i have had to replace both</TD></TR></TABLE>
nope...
What happens when you try to start it after it died?
fs
nope...
fs
Hi.
I have a Honda accord 2.0i, (1990).
I live in Norway, I have the same problem *** u, I was on a gas station here in my home town, And they had an expert on honda accord`s, He said that the problem was the motor control piece, or Motor control unit.
I get this problem if i try to start the car to fast, but u can try to check ur batteri, Becouse I cleaned my battery electrode, today, and used some battery electrode grease on it, and it started 8 times a row, easy.
Pls try this, and give me a repport
Have you replaced the PGMFI relay? It is under the dash. I had the same issue, and it fixed it. The board on the relay will not work too well when either hot or cold.
Just my .02.
It was around $50 from my dealer.
You might be able to fix the relay if you are good with soldering iron and cicruit boards.
Just my .02.
MattTwinTurbo
Aug 7, 2002 10:05 PM
