Koni Red adjustment tool.
Old Nov 29, 2004 | 11:22 PM
dumbass's Avatar
Default Koni Red adjustment tool.
Has anyone ever heard of or used this tool before?
http://www.928motorsports.com/parts/shocktool.html
The company sells mostly Porsche 928 parts, but I emailed them and was told that the tool will work with any car equiped with Koni Reds. It's basically an 18" 6mm allen key. Thoughts, opinions, comments.
Old Nov 30, 2004 | 04:53 AM
EE_Chris's Avatar
Default Re: Koni Red adjustment tool. (dumbass)
I have Koni Reds on my 99 hatch. To adjust them, you need to push the shock piston all the way in and turn left/right - meaning, you need to put the shock shaft, padded with something, in a bench vise, then push the shock body up all the way and turn it clockwise/counter clockwise.
So....I don't see how this tool would help.
Old Nov 30, 2004 | 06:35 AM
AutoXer's Avatar
Default Re: Koni Red adjustment tool. (EE_Chris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">To adjust them, you need to push the shock piston all the way in and turn left/right</TD></TR></TABLE>
I thought the reds were unadjustable? Is this for stiffness or shock travel?
Old Nov 30, 2004 | 07:08 AM
SiYouLater's Avatar
Default Re: Koni Red adjustment tool. (EX_AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX_AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">
The red have to be removed to be adjusted.
Old Nov 30, 2004 | 08:59 AM
dumbass's Avatar
Default Re: Koni Red adjustment tool. (99FBPSi)
They are adjustable for stiffness, but the rod needs to be compressed and turned a certain way locking them at 1 of 3 desired settings. All the tool does is compress the rod, not the shock body. This is part of an email I received from them...
"No, it does not take a lot of pressure, as the shock is only resisting, you
are not compressing the spring at all. It works on all Koni reds with the 6
mm Allen in the top."
Old Nov 30, 2004 | 09:00 AM
EE_Chris's Avatar
The Reds can be adjusted for stiffness - I think only rebound though. It has about 4-5 'turns' worth of adjustment range - so its not like a click-type of setting - you just count the #'s of turns from a full lock position.
On Koni's website, they have the adjustment procedure posted there.
Old Nov 30, 2004 | 09:03 AM
EE_Chris's Avatar
Oh I see - so you have to take off the locking nut holding the top hat assembly together and using this tool, you compress the shock shaft down - I could see that working.
Old Nov 30, 2004 | 09:08 AM
dumbass's Avatar
It's only $40 and they said I could return it if I'm not satisfied.
Old Nov 30, 2004 | 09:23 AM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">The Reds can be adjusted for stiffness - I think only rebound though. It has about 4-5 'turns' worth of adjustment range - so its not like a click-type of setting - you just count the #'s of turns from a full lock position.
On Koni's website, they have the adjustment procedure posted there.</TD></TR></TABLE>
Cool. Thanks for the info everyone. I was under the impression from everything that I read that the reds were unadjustable.
Old Nov 30, 2004 | 10:50 AM
94eg!'s Avatar
#1 Super Guy
Loved
Thats a really great idea. I can't believe Koni didn't think of that first, and sell the **** out of these things (Then they probably wouldn't be able to sell yellows). I wonder if the valveing on reds is the same as yellows? If so, I would have bought reds instead of paying way more for yellows (and having to strip that ugly yellow paint & clearcoat 'em).
Old Nov 30, 2004 | 04:07 PM
dumbass's Avatar
Default Re: Koni Red adjustment tool. (94eg!)
I ordered one today, so I'll update the post when I try it out.
raffaelli
Suspension & Brakes
16
Jan 27, 2009 08:27 AM
GreenGSR311
Sep 14, 2004 06:36 PM
typeeg
Sep 30, 2003 08:30 PM
hoya_10fintec
Apr 21, 2002 11:33 PM
pcorad
Apr 21, 2002 08:48 PM
