Want a slight bit more power.
Old Nov 29, 2004 | 07:31 PM
DCApex8's Avatar
Default Want a slight bit more power.
Okay, i've got an Automatic LS as a daily driver, have intake/headers/exhaust as my current mods.
I'm looking for a little bit more power, thats not going to be overly expensive, just to get a bit more passing power on the high way. Want to stay All-Motor, so yeah, any suggestions as to what I could put on for a bit more power? Preferrably something that'll net me a bit of low-mid range torque?
Old Nov 29, 2004 | 07:45 PM
b16a27's Avatar
Default Re: Want a slight bit more power. (DCApex8)
you could get under drive pullys and even cut power steering out(but if daily driver i wouldent) but it help for me i felt the diff.
Old Nov 29, 2004 | 07:56 PM
DCApex8's Avatar
Underdrive pulleys, hmm..Thanks, I'll look into them.
Definately wanna keep Power steering if possible--Makes the numerous u-turns i have to make due to odd store locations much easier.
Old Nov 29, 2004 | 08:06 PM
Kgb's Avatar
Kgb
Default Re: (DCApex8)
remove a/c, i dont know if cams would help u out since u have a/t, i think tune up will be your best bet as it may give u some lost hp if ur car has lots of miles on it.
Old Nov 29, 2004 | 08:18 PM
Master23's Avatar
Some good performing tires on a nice set of wheels will help out too.
Old Nov 29, 2004 | 08:28 PM
DCApex8's Avatar
Sitting on brand new Michellin's currently. Car was recently tuned up..Stock rims thugh..
Hmm, have I reached the peak of power without delving into the expensive mods and drastically hurting ride quality?
Old Nov 30, 2004 | 07:47 PM
sooo_slow's Avatar
New User
Get a new Chip..like JETCHIP or get the venom programmer..its really good..u can adjust the shift points..fuel curves..can get really detailed..just an idea..i have AEM underdrive pulleys and u can feel the difference too..good but i paid 188.00 but thats canadian
Old Nov 30, 2004 | 07:59 PM
Outkast95LS's Avatar
Default Re: (sooo_slow)
Wow.. great way NOT to give information. A new chip? Removing AC?
Ok, for one, the transmission does not in anyway have any direct relation to whether or not you can install cams. In fact, cams are a good upgrade, depending on how much you would like to spend. I'll be honesst, your automatic transmission is the biggest drawback in gaining good power. Its no use to get high power upgrades when your transmission is the weakest link in your set up. Considering doing a transmission swap. There are a few threads circulating right now on HT that are concerning this swap.
civic_speed99
Audio / Security / Video
Apr 20, 2005 07:05 AM
J-Spec EG
Dec 4, 2004 11:24 PM
HybridGSR1
Sep 26, 2002 02:31 AM
