quick question: difference between d16y8's?
Old Nov 29, 2004 | 04:35 PM
lkailburn's Avatar
Default quick question: difference between d16y8's?
back in the fall i picked up a y8 long block from a local guy. the guy i got it from was under the impression it came from california, because he said the intake mani was slightly different ..or something like that..
is anything on the head different than the rest of the y8's out there because it came from cali(stricker em laws and junk). any design differences or something that might cause leaks or something if i swap it onto my y7
thanks guys,
-Luke
Old Nov 29, 2004 | 04:44 PM
93egSIboi's Avatar
Default Re: quick question: difference between d16y8's? (lkailburn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">back in the fall i picked up a y8 long block from a local guy. the guy i got it from was under the impression it came from california, because he said the intake mani was slightly different ..or something like that..
thanks guys,
-Luke</TD></TR></TABLE>
Kinda hard to tell if its different without a picture...post one up of the mani and maybe we can help.
Old Nov 29, 2004 | 04:52 PM
Archidictus's Avatar
Unceasing Measure
As far as I know, all Hondas are 50-state legal and unchanged from state to state. It'll be fine.
Old Nov 29, 2004 | 07:11 PM
lkailburn's Avatar
yah i didn't think there was any differences but i'll post up a pic of my y8 intake mani(did not come on the cali long block i bought), a y8 IM gasket(straight from honda) and the y8 head(supposedly from cali and might be different according to that guy)
thnx guys i'll put up the pics asap
Old Nov 29, 2004 | 07:53 PM
inane's Avatar
Default Re: (lkailburn)
i dunno about the intake manifold but there are minor changes to the engine between 96-98 and 99-00
the 96-98 model is obd2a and the 99-00 model is obd2b and has an extra plug on it...
Old Nov 30, 2004 | 02:02 PM
lkailburn's Avatar
k i got some pics. notice the differences between the gasket and the mani and the gasket and the head etc.
also on the head you can see some old gasket residue on places the new gasket or mani isn't even touching.
lemme know what you guys think
Old Nov 30, 2004 | 02:21 PM
jdm169's Avatar
the difference is in the years. a 99-00 and the 96-98 manifold are different. one has cold start assist or something
Old Nov 30, 2004 | 02:28 PM
jdm169's Avatar
Default Re: (jdm169)
you see where there used to be gasket above the manifold on yours... now look at my gasket. see the difference? i think it would run fine either way though
Old Nov 30, 2004 | 02:37 PM
lkailburn's Avatar
jdm169- is urs a 99-00?
now that i recall, the guy did say it was a 2000
would these differences cause any leaks or anything?
Old Nov 30, 2004 | 02:51 PM
jdm169's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn &raquo;</TD></TR><TR><TD CLASS="quote">jdm169- is urs a 99-00?
would these differences cause any leaks or anything?</TD></TR></TABLE>
sorry i can't remember which i have, i think as long as you have the right gasket for the manifold your using you will be fine. maybe someone else could chime in will a definite answer
Old Nov 30, 2004 | 03:03 PM
Redline96LX's Avatar
* B A N N E D *
weve got info on this. the 99-00 is different from something called air injection. putting this manifold on a 96-98 car requires that you plug those holes with something
Old Nov 30, 2004 | 03:05 PM
Tad's Avatar
Tad
what about the 92-95 vs the 96-98 ?
any difference there as far as the mounting surface/gaskets go ?
Old Nov 30, 2004 | 03:11 PM
vtekstorm's Avatar
Default Re: (Tad)
96 to 98 compared to the 99 00 manifold is that the 99 00 has an air injection valve on it it does have something to do with cold starting
Old Nov 30, 2004 | 03:16 PM
civic99b16a's Avatar
Default Re: (vtekstorm)
the 99 had a iacv valve but so should the 96-98
Old Nov 30, 2004 | 03:30 PM
lkailburn's Avatar
the intake mani did not come on the y8 longblock i bought. im not sure what year the y8 mani is. i bought it seperatly but im pretty sure its 96-98 cuz i don't see the holes for the cold start thing
Old Dec 2, 2004 | 01:32 PM
lkailburn's Avatar
anyone else? opinions
Old Dec 2, 2004 | 02:37 PM
Marauder's Avatar
Your head is from a 99-00 with air-injection. The manifold is from a 96-98. Everything will work fine the way it is. There will not be any vacuum leaks or problems. Just go for it!
You'd only have a problem putting a air-injection manifold on a non air-injection head.
Old Dec 2, 2004 | 03:58 PM
lkailburn's Avatar
kool thanks marauder!!
im hopein to see some fun gains from this. should be nice after the boost goes on too
d-series !!!!!!
civic46
Apr 13, 2010 07:20 PM
NEWcivicLOVER
Oct 29, 2008 07:27 PM
BiG_DeE
Nov 1, 2007 06:37 PM
jArceo
15
Mar 31, 2004 10:35 AM
JDMlyfestyle
Jun 16, 2003 06:54 AM
