removing rotor from dizzy, safe way to turn it?
Old Nov 29, 2004 | 10:00 AM
dmxsoulja3's Avatar
Default removing rotor from dizzy, safe way to turn it?
I see the idea is that there is a screw holding it on, but the rotor is pointing in the wrong direction for me to get it, how can I move it? can I put the key in and turn the car over a few times with no wires and cap installed? And once its moved, am I correct in thinking it should go back on where it came off, or does this car have a certain place it lines up with no matter where it was before? I put the new plugs in already. so I'm not sure how to procede.
Thanks. Josh
Old Nov 29, 2004 | 10:14 AM
wootcivic's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (dmxsoulja3)
Josh,
What i might consider doing is, plug everything back in, turn the motor over and proceed again. Your rotor is only going to go on one way as it has a slot that the cam matches with the screw to hold it all in place.
Another way is to turn the motor by hand using a braker bar.
Modified by wootcivic at 7:24 PM 11/29/2004
Old Nov 29, 2004 | 10:16 AM
racekar's Avatar
i just take off passenger side tire or you can do it with it on with car jacked up. and use a socket with extension 17 mm i think and trun the crank cant remember which way counter or clockwise though, i think its counter though. and just keep turning it till you can access the rotor screw
Marauder's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (wootcivic)
I have just cranked it by tapping the ignition until it lines up, after taking the cap off.
Old Nov 29, 2004 | 10:18 AM
dmxsoulja3's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (Marauder)
thanks for the help guys, I guess I will try putting everything back on and firing it up and seeing if I can get a good luck stroke and line it up, if not I will get to the crank and turn it..
Old Nov 29, 2004 | 10:21 AM
JeffS's Avatar
Why not just remove the distributor?
Old Nov 29, 2004 | 10:24 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (racekar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">i just take off passenger side tire or you can do it with it on with car jacked up. and use a socket with extension 17 mm i think and trun the crank cant remember which way counter or clockwise though, i think its counter though. and just keep turning it till you can access the rotor screw</TD></TR></TABLE>I dont think you need to take it off just turn it and you can do this
Old Nov 29, 2004 | 10:30 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (2FAST4U831)
It is okay to turn the ignition over w/o the cap or wires on. This is how every mechanic removes a distributor rotor. This will not harm your engine. It's easiest to use two people (one turns the key, while one watches the rotor).
Old Nov 29, 2004 | 10:48 AM
743power's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It is okay to turn the ignition over w/o the cap or wires on. This is how every mechanic removes a distributor rotor. This will not harm your engine. It's easiest to use two people (one turns the key, while one watches the rotor). </TD></TR></TABLE>
No harm in turning the key, its the easiest way, just tap it a couple times and go out and check to see if it lines up. I usually get lucky and the screw is where I need it to be. . .
Old Nov 29, 2004 | 02:43 PM
Brian Hinson's Avatar
I just replaced my Distributor cap an rotor button, and turned the key to bump it over.
But, The new rotor button didnt come with a screw, is just popped into place sort of. Is this wierd?
Old Nov 29, 2004 | 02:48 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: removing rotor from dizzy, safe way to turn it? (BrianHinson)
It didn't come w/ a screw, or it didn't come w/ a screw hole?
Your supposed to reuse your old screw to hold the new rotor in place. If the rotor shifts or comes off, it could destroy your distributor.
Old Nov 29, 2004 | 03:39 PM
It didnt come with a screw or a screw hole
Old Nov 29, 2004 | 03:40 PM
marshun's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It didn't come w/ a screw, or it didn't come w/ a screw hole?
Your supposed to reuse your old screw to hold the new rotor in place. If the rotor shifts or comes off, it could destroy your distributor.</TD></TR></TABLE>
or cause a wrong plug to spark and then satan will come out of your motor and kill it
crazyguy
Aug 21, 2007 01:08 PM
highneo
Mar 7, 2007 09:22 PM
bupthmt
11
Apr 24, 2005 10:00 AM
doggunracing
Nov 6, 2003 09:24 PM
magic hat #9
Dec 30, 2002 07:12 PM
