removing rotor from dizzy, safe way to turn it?
Old 11-29-2004, 10:00 AM
dmxsoulja3's Avatar
Default removing rotor from dizzy, safe way to turn it?
I see the idea is that there is a screw holding it on, but the rotor is pointing in the wrong direction for me to get it, how can I move it? can I put the key in and turn the car over a few times with no wires and cap installed? And once its moved, am I correct in thinking it should go back on where it came off, or does this car have a certain place it lines up with no matter where it was before? I put the new plugs in already. so I'm not sure how to procede.
Thanks. Josh
Old 11-29-2004, 10:14 AM
wootcivic's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (dmxsoulja3)
Josh,
What i might consider doing is, plug everything back in, turn the motor over and proceed again. Your rotor is only going to go on one way as it has a slot that the cam matches with the screw to hold it all in place.
Another way is to turn the motor by hand using a braker bar.
Modified by wootcivic at 7:24 PM 11/29/2004
Old 11-29-2004, 10:16 AM
racekar's Avatar
i just take off passenger side tire or you can do it with it on with car jacked up. and use a socket with extension 17 mm i think and trun the crank cant remember which way counter or clockwise though, i think its counter though. and just keep turning it till you can access the rotor screw
Marauder's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (wootcivic)
I have just cranked it by tapping the ignition until it lines up, after taking the cap off.
Old 11-29-2004, 10:18 AM
dmxsoulja3's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (Marauder)
thanks for the help guys, I guess I will try putting everything back on and firing it up and seeing if I can get a good luck stroke and line it up, if not I will get to the crank and turn it..
Old 11-29-2004, 10:21 AM
JeffS's Avatar
Why not just remove the distributor?
Old 11-29-2004, 10:24 AM
I'm really 2slow
2fast4u831's Avatar
Default Re: (racekar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by racekar &raquo;</TD></TR><TR><TD CLASS="quote">i just take off passenger side tire or you can do it with it on with car jacked up. and use a socket with extension 17 mm i think and trun the crank cant remember which way counter or clockwise though, i think its counter though. and just keep turning it till you can access the rotor screw</TD></TR></TABLE>I dont think you need to take it off just turn it and you can do this
Old 11-29-2004, 10:30 AM
#1 Super Guy
94eg!'s Avatar
Default Re: (2FAST4U831)
It is okay to turn the ignition over w/o the cap or wires on. This is how every mechanic removes a distributor rotor. This will not harm your engine. It's easiest to use two people (one turns the key, while one watches the rotor).
Old 11-29-2004, 10:48 AM
743power's Avatar
Default Re: (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It is okay to turn the ignition over w/o the cap or wires on. This is how every mechanic removes a distributor rotor. This will not harm your engine. It's easiest to use two people (one turns the key, while one watches the rotor). </TD></TR></TABLE>
No harm in turning the key, its the easiest way, just tap it a couple times and go out and check to see if it lines up. I usually get lucky and the screw is where I need it to be. . .
Old 11-29-2004, 02:43 PM
Brian Hinson's Avatar
I just replaced my Distributor cap an rotor button, and turned the key to bump it over.
But, The new rotor button didnt come with a screw, is just popped into place sort of. Is this wierd?
Old 11-29-2004, 02:48 PM
#1 Super Guy
94eg!'s Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (BrianHinson)
It didn't come w/ a screw, or it didn't come w/ a screw hole?
Your supposed to reuse your old screw to hold the new rotor in place. If the rotor shifts or comes off, it could destroy your distributor.
Old 11-29-2004, 03:39 PM
It didnt come with a screw or a screw hole
Old 11-29-2004, 03:40 PM
marshun's Avatar
Default Re: removing rotor from dizzy, safe way to turn it? (94eg!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94eg! &raquo;</TD></TR><TR><TD CLASS="quote">It didn't come w/ a screw, or it didn't come w/ a screw hole?
Your supposed to reuse your old screw to hold the new rotor in place. If the rotor shifts or comes off, it could destroy your distributor.</TD></TR></TABLE>
or cause a wrong plug to spark and then satan will come out of your motor and kill it
crazyguy
08-21-2007 01:08 PM
highneo
03-07-2007 09:22 PM
bupthmt
11
04-24-2005 10:00 AM
doggunracing
11-06-2003 09:24 PM
magic hat #9
12-30-2002 07:12 PM
Quick Reply: removing rotor from dizzy, safe way to turn it?
