Did search. Trouble starting the gsr.
Old Nov 29, 2004 | 06:31 AM
Drian's Avatar
Default Did search. Trouble starting the gsr.
I try to start the car and it gives ONE click and doesnt start. I get power, but one click and no go. I have to turn the key back off and start a couple of times then it comes to life barely. My battery is fairly new, I replaced the fuel filter, plugs n wires. I'm thinking maybe the connection from the battery to the starter? Any one else have a suggestion? Thanks in advance!
Old Nov 29, 2004 | 06:40 AM
stasi's Avatar
Default Re: Did search. Trouble starting the gsr. (Drian)
Here's a basic guide from another site:
Engine Related Problems
Engine will not rotate when attempting to start
- Battery terminal connections loose or corroded.
- Battery discharged or faulty.
- Automatic Transmission/transaxle not completely engaged in Park mode or Manual Transmission Clutch not completely depressed.
- Broken, loose or disconnected wiring in the starting circuit.
- Starter motor pinion jammed in flywheel ring gear.
- Starter solenoid faulty.
- Starter motor faulty.
- Ignition switch faulty.
- Starter pinion or flywheel teeth worn or broken.
Engine rotates but will not start
- Fuel tank empty.
- Battery discharged.
- Leaking fuel injectors, faulty fuel pump, faulty fuel pressure regulator.
- Fuel not reaching the fuel rail.
Ignition components damp or damaged.
- Worn, faulty or incorrectly gapped spark plugs.
- Loose distributor is changing ignition timing.
- Broken, loose or disconnected wires at the ignition coil or faulty coil.
Old Nov 29, 2004 | 06:43 AM
Drian's Avatar
Thanks. Gonna start on the ignition switch/starter solenoid. Peace!
Old Nov 29, 2004 | 07:07 AM
AngelTeg's Avatar
Default Re: (Drian)
happened to my teg too... the way you describe it actually brought back some bad memories...
get your starter replaced. if you're cheap like me, just get a reman and give your core back... that's the cheapest way to go.
-Mike
Old Nov 29, 2004 | 08:31 AM
marsbike's Avatar
From: Salt Lake City, Chicago at heart, UT or IL, USA
Default Re: (AngelTeg)
on mine, sometimes pushing the clutch slightly to the right will help resolve the problem. If you push the clutch straight down, sometimes, in my car at least, it won't start. Just a little pressure from rotating your ankle is all nesecairy.
jgett002
Aug 3, 2016 02:00 PM
Jenn Lindlau
20
Apr 30, 2012 03:28 PM
go2sleep
May 6, 2007 08:42 PM
blusmke
Dec 1, 2004 10:02 PM
mingchi69
Jul 14, 2003 06:14 PM
