what specs should my vafc be for all motor??
Old Nov 28, 2004 | 05:06 PM
hybridpatient95's Avatar
Default what specs should my vafc be for all motor??
this kid on my town has a crvtec all motor and he was wondering if anyone knows good specs for a vafc?? cuz were going back to all motor. it was boosted but lacked top end cuz of the small turbo and my friend wants his kit back. so can any one leave some good specs for us to try???
Old Nov 28, 2004 | 05:10 PM
DEVIOUS_EG*'s Avatar
Default Re: what specs should my vafc be for all motor?? (kinkbmx159)
the best "spec's" for your VAFC, is to bring it to a dyno w/ a wideband.. that's the only way i see .. good luck
Old Nov 28, 2004 | 05:13 PM
hOndafienD 04's Avatar
aiiight
Old Nov 28, 2004 | 06:12 PM
UnKnownUser's Avatar
Default Re: what specs should my vafc be for all motor?? (DEVIOUS_EF*)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DEVIOUS_EF* &raquo;</TD></TR><TR><TD CLASS="quote">the best "spec's" for your VAFC, is to bring it to a dyno w/ a wideband.. that's the only way i see .. good luck </TD></TR></TABLE>
Old Nov 28, 2004 | 07:52 PM
ok but whats a good setup until we get the car dynoed?
Old Nov 28, 2004 | 09:02 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (hOndafienD 04)
what ECU?
IMO, there is no sense in playing with it b4 dyno day, because at this point, that is really all you will be doing, playing...
drive it easy and get to the dyno ASAP.
Old Nov 28, 2004 | 09:45 PM
chipped p28
Old Nov 29, 2004 | 11:05 AM
true man but is there any type of setting that i can use so itll run fine??
Old Nov 29, 2004 | 06:27 PM
builthatch's Avatar
MiG-21 superfan
Default Re: (kinkbmx159)
is it running badly on the p28?
Old Nov 30, 2004 | 01:36 PM
Default Re: (builthatch)
havent tryed it yet . right now the car is lean as ****!!! the gauge works i hope idk im gonna check it out tomorrow. but like the very first bar on lean is only lit!! so idk man im gonna check the gauge and try to run it of the p28.
Old Nov 30, 2004 | 01:39 PM
would the car like bog since the the gauge says lean. cuz it runs fine. its just that gauge scares me. like it doesnt cut out or anything all gears run strong..
Old Nov 30, 2004 | 04:48 PM
builthatch's Avatar
MiG-21 superfan
what gauge are you referring to?
Old Nov 30, 2004 | 05:25 PM
hes refering to an autometer air/fuel gauge.
Old Nov 30, 2004 | 05:30 PM
builthatch's Avatar
MiG-21 superfan
that gauge is good for nothing but a light show- you need to find a friend with a wide band and do some pulls, just to ge the a/f about right with the vafc, then dyno as soon as possible to find out what makes power and what doesnt.
Old Nov 30, 2004 | 06:06 PM
true man!! do you have any experiece with the vafc?!?!
94eg4
Jun 15, 2006 07:32 AM
92SiBlu
Jun 17, 2004 02:55 AM
DC2fanboy
Dec 22, 2003 10:56 AM
CPR
Nov 9, 2002 07:26 AM
ITR 01-0840
Jan 7, 2002 04:59 PM
