tranny swap
Old Nov 28, 2004 | 04:11 PM
95'turbotegra's Avatar
Default tranny swap
could some one please tell me where to find the things i need to make a tranny swap from a automatic to a standard tranny on a 95 integra. if anyone has some info on the topic please drop me a line
Old Nov 28, 2004 | 05:36 PM
XkjeldorX's Avatar
Default Re: tranny swap (95'turbotegra)
u would need the a manual tranny, manual ecu, the clutch pedal and clutch line? clutch cylinder shift linkage and not sure what else.
someone else post if anything else needed
Old Nov 28, 2004 | 06:09 PM
Modified Motors's Avatar
Default Re: tranny swap (XkjeldorX)
Tranny
Tranny motormount from pace racing for auto to manual
Master and slave cylinders, and all the lines in between
Rear motor mount l braket
Manual ecu
Shiftlinkage
a welder
clutch, and flywheel
tranny fluid
clutch fluid
Complete pedal assembly...you need a smaller brake and gas and brake are connected.
Some wiring diagrams
gauge cluster if you want
Also for a cleaner look you might want the center console from a manual.
Check the classifieds, along with ebay and your local junkyards for parts
Alude99
Sep 25, 2007 05:04 PM
fantasya98
Aug 20, 2006 08:41 AM
AznInvasion
Sep 12, 2003 06:19 PM
Mugen13
Mar 22, 2002 05:17 PM
PolosportZ81
Oct 2, 2001 07:07 AM
