Blow-by testing on cold H22A engine. Questions!
Ok,
I've got a motor that I'm planning on using for a swap.
I decided to attempt to use a MAC blow-by tester to determine if there was a lot fo blow-by... or if there was anything I should worry about.
I'm finding the #1 has 20 psi, #2 has 40 psi, #3 has 0 psi, #4 has 95 psi.
(That would translate to 80%, 60%, 100%, and 5% loss or blow-by.)
So the question is...
After a motor has been sitting for a while and is cold... is there a reason to suspect these reading are completely inaccurate?
Also, do I need to be putting oil in the cylinders to get a proper reading? If so... how much?
Ok...
*Update*
I was speaking with a mechanic friend and he told me to adjust the valves.
He also indicated that sometimes the valves, after sitting for a while, may have crud on them. Setting the piston to the lowest part of it's individual cycle a lightly tapping the adjustment screw will somethimes clear that crud.
Guess what... IT WORKED.
It was obvious that the problem were valves... as I rotated the motor and began the closed valves part of the cycle, you could painly hear when the valves were not seating. (Hiiiiiiisssssssss)
Once that was fixed I saw between 95-100 PSI with the leakdown tester in each cylinder!
Looks like the valves and the pistions / rings are all fine.
(That was my biggest concern with a used motor!)
Gerhard
*Update*
Gerhard
HotWheelz
Jan 27, 2003 05:42 AM
