Big cams in a b16
Old Nov 28, 2004 | 03:39 PM
grenthang's Avatar
Default Big cams in a b16
Would it be a good idea to run some buddy club 3 or skunk 2 stage 2 or blox cams in my first gen b16 with the stock compression. I am running an 01 itr intake cam now with skunk 2 valve train and type r retainers so the valve train isnt a problem.
Old Nov 28, 2004 | 03:55 PM
jdmHboy's Avatar
Default Re: Big cams in a b16 (grenthang)
The skunk2 stage 2's would be too wild for stock compression. Buddy club's would be okay though.
Old Nov 28, 2004 | 05:38 PM
grenthang's Avatar
Default Re: Big cams in a b16 (jdmHboy)
so u think i can get maxium power out of the cams without the compression.
Old Dec 7, 2004 | 08:17 PM
-Justin-'s Avatar
i would like to bump this up for some suggestions on this subject. i might be gettin a set of s2s2's myself and would like to know about this.
Old Jan 16, 2005 | 02:09 PM
warwagon's Avatar
one more try
Old Jan 16, 2005 | 04:47 PM
blue skunk2's Avatar
As long as you clay check the piston valve relief cut outs on the pistons to make sure the cam lobes are not to big that the valve does not smack the piston.
Old Jan 16, 2005 | 05:41 PM
rtmiami's Avatar
Default Re: Big cams in a b16 (blue skunk2)
I don't think you'll have a problem with the skunks. I ran a set of Crane Stage III's on my (basically) stock B16a EF. What your gonna loose by running the "big" cams are the very little torque you had.
It gave me NASTY top end thou
Try a Stage 1 or Toda Spec A (kinda pricy!!)
serr38
Oct 31, 2007 12:45 PM
Top Ramen
Aug 15, 2006 05:34 PM
HBoy
Jun 21, 2005 12:57 PM
roadawg
Dec 8, 2003 09:17 AM
