Turbonetics 60-1 or Precision which one???
Old Nov 28, 2004 | 02:10 PM
POWERINTEGRA's Avatar
Default Turbonetics 60-1 or Precision which one???
I just wonder which turbo is better to be use and what is the price range for a turbonetics 60-1 turbo and a precision which one is best to use and why, also what is the price different between the both.
I got an offer on a precision turbo
and turbonetics 60-1 with same spec.
But really which one is best. What are you guys using out there???
Old Nov 28, 2004 | 02:11 PM
11psiTurboSI's Avatar
Default Re: Turbonetics 60-1 or Precision which one??? (POWERINTEGRA)
Precision
Old Nov 28, 2004 | 02:18 PM
alpha's Avatar
I have always used Precision turbochargers. They have a good warranty (one year or twelve thousand miles), a wide selection of turbochargers, use their own casted turbine housings, great customer support (from dealers and them) and most of their turbochargers use a good wheel combination. I have a Precision GT30R on the way right now. It's basically a Garrett GT30R with a Precision turbine housing.
Old Nov 28, 2004 | 02:19 PM
Default Re: Turbonetics 60-1 or Precision which one??? (0x64)
anybody got input on the turbonetics 60-1??
Old Nov 28, 2004 | 02:55 PM
h22 civic's Avatar
precision my personal experience with turbonetics = blowing seals
Old Nov 28, 2004 | 02:57 PM
Default Re: Turbonetics 60-1 or Precision which one??? (h22 civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22 civic &raquo;</TD></TR><TR><TD CLASS="quote">precision my personal experience with turbonetics = blowing seals</TD></TR></TABLE>
How about if they both come with 1 year warranty would this make a difference??
what is really the big difference over the turbonetics and the precision??
Better seals that might be one what else really?
Old Nov 28, 2004 | 03:05 PM
B18C1CYA's Avatar
well depends realy , the precision sc61 comes with the 360 degree thrust bearing standard , i dont know if the turbonetics does or if it is extra?? i used to have a turbonetics until it craped out and now iam precision
Old Nov 28, 2004 | 03:09 PM
Default Re: Turbonetics 60-1 or Precision which one??? (B18C1CYA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">well depends realy , the precision sc61 comes with the 360 degree thrust bearing standard , i dont know if the turbonetics does or if it is extra?? i used to have a turbonetics until it craped out and now iam precision </TD></TR></TABLE>
ummm yeah anybody has more input on this???
Old Nov 28, 2004 | 03:10 PM
alpha's Avatar
SC61 is not the only Precision turbocharger that comes standard with 360 degree thrust bearing
Old Nov 28, 2004 | 03:12 PM
B18C1CYA's Avatar
i wasnt shure on that so i didnt want to misinform, so do they all have the bearing?? if so then
Old Nov 28, 2004 | 03:13 PM
This is what I got from turbonetics web site. Whics precision will compare to this??? Anyone knows??
The 60-1 Performance Turbocharger
Representing the careful marriage of a unique high flow/high efficiency compressor section teamed up with a T4 turbine section the 60-1 has proven itself in every competitive motorsport application from drag racing to Bonneville. Available with either the standard (4" inlet, 2.5" discharge) compressor housing or the 60-1 HI-FI ( 2 3/4" inlet, 2" discharge) compressor housing, the 60-1 will outflow any standard T04B with ease! (The 60-1 HI-FI will deliver approximately 90-95% of the flow capacity of the standard 60-1.)
The 62-1 Performance Turbocharger
The 62-1 represents TURBONETICS' efforts to produce a premium turbocharger for the engine builder looking for that extra "edge" of power. Based on hand selected compressor components precisely contoured on computer controlled machining centers, the 62-1 delivers an honest 10% greater airflow than the standard 60-1. The 62-1 is not for every one, but if you can handle its potential, the expense will be well worth it.
BOTH THE 60-1 AND THE 62-1 ARE AVAILABLE WITH THE EXCLUSIVE TURBONETICS "TUFF TURBO" OPTION FOR SUPERIOR DURABILITY!
Old Nov 28, 2004 | 03:24 PM
anyways how good is turbonetics?
how good is precision?
Are both about the same?
Old Nov 28, 2004 | 03:28 PM
turboEGhatch's Avatar
Turbonetics customer service sucks. PTE's service kicks ***. I had a T'netics turbo that blew the seals and needed rebuilding, and it was a bitch to get anything done. Rod and the gang @ PTE run a top notch business.
Old Nov 28, 2004 | 03:31 PM
AVATAR's Avatar
Precision turbos have been proven numerous times on this site, as has their customer service
Turbonetics has had a bad rep. from awhile ago about blowing the seals or leaking AND they were known for having really shitty customer service. So think about it . . . . .
Turbonectics does supply quite a few turbos to ome of the Hot Rod and Pro guys, so maybe their higher line of turbos has more as far as quality control goes. I also *heard* turbonectics were alittle more friendlier now then they used to be.
bottom of the line 60-1 wheel was the **** . . . back in the day.
the SC61's GT wheel owns it now.
Old Nov 28, 2004 | 04:28 PM
h22 civic's Avatar
Default Re: Turbonetics 60-1 or Precision which one??? (AVATAR)
contact arturbo on this forum and be done with any turbonetics head aches (my personal opinion)
Old Nov 28, 2004 | 05:15 PM
what is the price range for this kind of turbos if anyone knows?
Old Nov 28, 2004 | 06:01 PM
AVATAR's Avatar
dude the search function = your friend
check sponsors marketplace in forced induction. They can be had under $700 including shipping . . . but it'll vary as some vendors can give the homie hookup.
Old Nov 28, 2004 | 06:23 PM
thansks for the help guys
Old Nov 29, 2004 | 08:37 AM
RyanEJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C1CYA &raquo;</TD></TR><TR><TD CLASS="quote">i wasnt shure on that so i didnt want to misinform, so do they all have the bearing?? if so then </TD></TR></TABLE>
All the SC series have the 360 deg bearing.
Old Nov 29, 2004 | 11:40 AM
Default Re: Turbonetics 60-1 or Precision which one??? (RyanCivic2000)
I didn't know this but turbonetics is using the 360 degree thrust bearing on all the new turbos and the 60-1
Trim 60-1
compresor-60-1
turbine you can pick stage II V etc...
I know a couple of cars running the 60-1 with no problems for over 3 years
The turbo is rated for 600HP + for 9 sec. cars
If all the inf. I was given is correct this might equal a precison turbo.
We really need someone that knows both turbos to the heart it seems like they might be a match and both might be same quality, using same parts, specs etc.
I'm not sure would someone clear this
Modified by POWERINTEGRA at 8:55 PM 11/29/2004
Old Nov 29, 2004 | 04:02 PM
anymore input???
mazdaturbo10
Aug 23, 2011 07:42 AM
Sincere
Feb 13, 2004 11:49 AM
Se-rv-Tak
Sep 24, 2003 02:54 AM
