Perma-Dry???
Old Nov 28, 2004 | 01:41 PM
DrewQ1's Avatar
Default Perma-Dry???
I'm replacing my valve cover gasket and sparkplug tube seals on my 95 ls and i was told that i would need honda bond or a gasket sealent. But on the box for the gaskets is says dont use with any other chemicals. so is that okay or if it was another type of gaskets made from someone else than it would be okay, let me know, thanks!
Old Nov 28, 2004 | 02:31 PM
rtype11's Avatar
Default Re: Perma-Dry??? (DrewQ1)
even the fel pro replacement kit says to use rtv in the corners of the gasket and around cam profile, tube seals no rtv silicone.
Old Nov 28, 2004 | 03:19 PM
skunk2finatic's Avatar
Default Re: Perma-Dry??? (rtype11)
I think he is using felpro gaskets.... he did mention a box. They don't come like that from the dealer.
felpro
Old Nov 28, 2004 | 08:18 PM
DrewQ1's Avatar
Default Re: Perma-Dry??? (skunk2finatic)
whats wrongwith frl pro thats what they gave me at advance auto
Old Nov 28, 2004 | 08:21 PM
dfoxengr's Avatar
i think fel pro is perfectly fine. cheap too.
Old Nov 29, 2004 | 09:39 AM
rtype11's Avatar
cant believe i have to get back to this thread, fel pro is just fine! use a bit of rtv or honda bond in corners of vlave cover and around cams/cam seal (dizzy side) cant show you the pic of recommended locations , then gently press the gasket into place, allow some time for it to get tacky and install.
Old Dec 11, 2004 | 06:18 AM
DrewQ1's Avatar
any other objectives
davidt1
Apr 4, 2012 06:44 AM
BlueLude84
Feb 4, 2007 11:14 AM
rasinhell
Aug 8, 2005 01:00 PM
DrewQ1
Nov 28, 2004 08:20 PM
RicedREX
Feb 9, 2003 09:31 AM
