What is needed to get a good all motor setup...............
Old Nov 28, 2004 | 12:33 PM
integrakilla's Avatar
Default What is needed to get a good all motor setup...............
For all you flmers I know you need a motor, pistons and yada yada, but what is considered a good setup, what kind of compression, Isearched but only got a bunch of compressions for turbo
Old Nov 28, 2004 | 12:52 PM
Tbone's Avatar
Default Re: What is needed to get a good all motor setup............... (integrakilla)
Set your final goals for the car and what you want to accoplish then built it from there. There's to many Good setups to try to list them. You build to what your needs are.
Look at Bigteggie's car ..!1.5 cr daily driven making close to the same power as some of the full blow race setups here..
Old Nov 28, 2004 | 04:30 PM
BERT-O's Avatar
like hommie above said, also, start with a budget as well. from there, research and see what is suitable for you needs.
I.e. certain cams only do certain things on a motor.
certain headers only flow a certain way
in short, you will have your +s and -s. figure what you wnat.
Old Nov 28, 2004 | 06:23 PM
Terrible One's Avatar
Default Re: What is needed to get a good all motor setup............... (BERT-O)
will this be your daily driver? track car? both? how much comp are you planning to run? lots and lots of factors. gets those questions cleared up first then choosing you setup will be piece of cake.
jetspeedz
May 15, 2013 11:26 AM
I4BangN
Sep 7, 2008 09:39 AM
mhgleitz
Nov 19, 2003 03:33 PM
advance concepts
10
Jul 17, 2003 12:39 PM
12SecHatch
Feb 1, 2003 08:11 AM
