Back End Rattle
Old Nov 28, 2004 | 09:34 AM
92integraVTECgsr's Avatar
Default Back End Rattle
Something is rattling from my back end suspension area.. not sure what it is.. its not coming from the shock, spring, brake caliper.. Just wondering if anyone has had the same problem.. it only makes noise when going over bumps.
Old Nov 28, 2004 | 06:16 PM
Default Re: Back End Rattle (92integraVTECgsr)
any suggestions??? please.. its so annoying..
Old Nov 28, 2004 | 06:19 PM
2ndgentegracer's Avatar
It could be the rear heat shield.
Old Nov 28, 2004 | 06:58 PM
stasi's Avatar
Default Re: Back End Rattle (2ndgentegracer)
Er, um.....are you sure it's not the hatch?
Old Nov 28, 2004 | 09:36 PM
ya definitely not the hatch..i fixed that.. heat sheild no.. it sounds like its coming from the rear drivers side..something to do with suspension.... an arm or something loose or bushing gone.... i dont know..
Old Nov 28, 2004 | 09:46 PM
Marble's Avatar
Your rear hatch used to rattle? Mine does currently, how did you go about fixing this? Any help is greatly appreciated.
Thank you.
Old Nov 28, 2004 | 10:38 PM
UnionCity LS's Avatar
Default Re: Back End Rattle (ATXS2K)
do you have colilovers? if so it could be them...especailly if your car us dumped and the piece that spins is loose, it will "rattle" like you said..but if not good luck finding out...
check your res. i had a rattle once from the rear and ended up replacing my res, the baffle took a **** on me and was rattling pretty bad, but your rattle doesnt seem that severe.
Old Nov 28, 2004 | 10:50 PM
Marble's Avatar
Default Re: Back End Rattle (UnionCity LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UnionCity LS &raquo;</TD></TR><TR><TD CLASS="quote">do you have colilovers? if so it could be them...especailly if your car us dumped and the piece that spins is loose, it will "rattle" like you said..but if not good luck finding out...
check your res. i had a rattle once from the rear and ended up replacing my res, the baffle took a **** on me and was rattling pretty bad, but your rattle doesnt seem that severe.</TD></TR></TABLE>
What is "res?"
Old Nov 29, 2004 | 01:35 AM
Dc4turbo408's Avatar
that happened to me, its your heatshield. Take that **** out. I took mine out. ****
Old Nov 29, 2004 | 01:56 AM
SlipAngleX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATXS2K &raquo;</TD></TR><TR><TD CLASS="quote">What is "res?"</TD></TR></TABLE>
my guess is resonator?
Old Nov 29, 2004 | 05:34 AM
gearheadgirlie's Avatar
ATXS2K:
if its that metal on metal soundin rattle/clank coming from the truck latch put a LITTLE bit of electrical tape around it. dont get tape happy or else you wont be able to open and close it anymore. woops.
try to keep wrinkles out.
hope that helped.
Old Nov 29, 2004 | 07:05 AM
Default Re: Back End Rattle (SlipAngleX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlipAngleX &raquo;</TD></TR><TR><TD CLASS="quote">
my guess is resonator? </TD></TR></TABLE>
for sure.
Old Nov 29, 2004 | 03:21 PM
ya to fix the hatch rattle, use electric tape around the latch hook on the hatch..
and thanks for the help. ill look at all those possible problems.. oh ya.. its not the coilovers.. i had them and thought that was the problem so i bought eibach prokit(i was going to anyway) and still didnt solve the problem.
Old Nov 29, 2004 | 03:22 PM
TeaAddict's Avatar
its the bushings fo sho
Old Nov 29, 2004 | 03:40 PM
IntegraBoy04's Avatar
Default Re: Back End Rattle (TeaAddict)
My rear rattles too. Can't figure out what it is. All bolts are tight, but the suspsension is really stiff, so it might just be that.
Old Nov 29, 2004 | 05:49 PM
Marble's Avatar
Default Re: Back End Rattle (gearheadgirlie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearheadgirlie &raquo;</TD></TR><TR><TD CLASS="quote">ATXS2K:
hope that helped.
Thanks. I will try this out.
Old Nov 29, 2004 | 07:08 PM
.doeboyfresh.'s Avatar
From: Boswanna,street radio,riddin in da regal. PA.LLday
on the hatch hook there are shims under it if you wan it fixed unscrew and take it out or electrical tape works too
Old Nov 29, 2004 | 07:43 PM
rapid_roy's Avatar
If it doesn't make noise when you are cornering but does when you are going straight then it is probably the endlinks.
I pulled the spare and the cardboard piece out of the back, pulled back the carpet back and sat back there with my ear down on the floor while my brother drove around. I marked where the noise was coming from with a pencil and used that as a reference to find what suspension piece on the other side was closest.
Old Nov 29, 2004 | 09:08 PM
litlekikr's Avatar
My 97 gsr had the same problem but only after i installd an exhaust. I found out that one of the hangers slipped off and it was alowing (sp?) the exhaust to hit/rattle against some of the chassis. scared the hell out of me, i thought i broke something. Just something to check out. good luck
nutt45
Aug 7, 2009 04:58 PM
phikshin
Suspension & Brakes
Jun 11, 2009 12:03 AM
nguyenchuck
Nov 13, 2008 11:14 AM
spock_rocker
Oct 8, 2004 09:46 AM
