cel after swapping throttle bodies
Old Nov 28, 2004 | 01:48 AM
b18c1wes's Avatar
Default cel after swapping throttle bodies
i have a gsr motor and i just swapped throttle body from a 95 gsr. when i drive normallly its fine then i got on it and the cel came on and the car started sputtering..... im having my mechanic scan the cel.. but it has to be related to the throttle body because it happened right after and the car was fine when i started working on it... i replaced the map sensor on the throttle body but not the tps.. could the tps cause this to happen it only throws a code when i hit about 6000rpm..? i checked the tps by taking the plug to the switch off while the car was running and the cel came on. so its not completely bad but could the voltage be off or something.... ?
thanks wes
Old Nov 28, 2004 | 01:51 AM
b18c1wes's Avatar
Default Re: cel after swapping throttle bodies (b18c1wes)
BTW when i start my car up now the idle doesnt shoot up to 2 grand or so when its cold just idles at like 1k all the time.....
Old Nov 28, 2004 | 06:45 AM
boosted k20's Avatar
my bet would be a TPS sensor
Old Nov 28, 2004 | 04:05 PM
b18c1wes's Avatar
Default Re: cel after swapping throttle bodies (boosted k20)
thats what id like to hear considering thats the only sensor i used from the used throttle body....im going to let my mechanic scan the code tommorrow morning ill post up on what it is.... im sure from going rich the hesitation and sputtering is from fouled plugs.. i have like 12 backup plugs so oh well...
Old Nov 30, 2004 | 03:02 PM
b18c1wes's Avatar
i didnt get the computer to scan and the tps is a bitch to get off did i mention i have a donor throttle body and i had to hacksaw it to take it out with a flat head... i really hope this is it ... any one else have any idea... my key thing is on a cold start the idle doesnt go up just stays at 1000...?
Old Dec 1, 2004 | 01:34 AM
b18c1wes's Avatar
bump.... can someone help me out?
Old Dec 1, 2004 | 01:46 AM
b18c1wes's Avatar
im thinking its something besides the tps sensor my problem is stated above someone please help me out i dont wan to swap the tps if i dont have to its a biotch...
Old Dec 2, 2004 | 01:34 AM
b18c1wes's Avatar
Old Dec 2, 2004 | 04:49 PM
b18c1wes's Avatar
any takers?
Old Dec 7, 2004 | 02:50 PM
b18c1wes's Avatar
was the map sensor
Jeeptech
May 19, 2017 08:12 PM
brandynEG
Engine Management and Tuning
13
Sep 27, 2013 04:51 AM
ejoner
Oct 23, 2007 08:03 PM
SuzukaBlueAP2
Oct 16, 2003 02:39 PM
lilxvtecxpwr
Oct 18, 2002 08:16 PM
