Just removed power steering belt
Old Dec 30, 2001 | 08:40 AM
lilcasino's Avatar
Default Just removed power steering belt
All of 5 min to do it, should have done it sooner. I didn't notice that much more in power, but the driving is now different. Since I drive a 90 crx I know how it feels to drive a car w/o power steering. Has anyone else done this "mod"?
98 Integra
92 Civic
90 CRX
Old Dec 30, 2001 | 08:58 AM
PapaPark's Avatar
HT White Ops
Default Re: Just removed power steering belt (lilcasino)
I believe speedymon(he usually posts in the teg forum) did it to his teg. He said he could notice a little bit more power.
Old Dec 30, 2001 | 10:52 AM
BlackDeuceCoupe's Avatar
HT White Ops
Yep, this is fairly standard practice for racing. Taking the belt off your P/S and removing the lid from your OE airbox will give you approx a 8 [dyno-proven] HP gain.
Old Dec 30, 2001 | 02:17 PM
C4wrx's Avatar
Default Re: Just removed power steering belt (BlackDeuceCoupe)
all on a civic?
you actualy get a noticeable gain ?????????????????????
hell yeah im guna do it then
i hate driving in the rain with power steering, you cant tell if your gripping or not
Old Dec 30, 2001 | 05:32 PM
HT White Ops
Default Re: Just removed power steering belt (Jdmb18c)
all on a civic? you actualy get a noticeable gain ? hell yeah im guna do it then...
Yeah, it WILL make a difference. Honda is going to electric power steering on their 'new' CiViCs, instead of engine-driven. There's a method to their madness...
Old Dec 30, 2001 | 06:14 PM
KawiGreenVTEC's Avatar
Yes and this also blows the seals on a power steering rack.
Old Dec 30, 2001 | 06:17 PM
honda93's Avatar
So what do you plan on doing with all the weight adding equipment that accompanies the P/S unit? Does taking off the A/C belt mean I have made the car faster or 45 lbs. lighter? NO! It simply means I took the first (and easiest) step in lightening a car. Now I don't know what kind of racing you mean, but if you want to do it right, a manual rack and all its hardware should go in its place. Also, oh, never mind
Old Dec 30, 2001 | 06:49 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: Just removed power steering belt (honda93)
You've got to be kidding me..........
<sarcasm> OOHhh, I took of my p/s belt. I think I'm the first one!!! OOOOOOOOOOOOO
Anyone else do this???????????</sarcasm>
Gimme a F'ing break kiddies. DO A SEARCH!!!!!!!!!!!!!!
https://honda-tech.com/zerosearch
OR READ THIS...
https://honda-tech.com/zeroforum?cmd...nnounce&id=6#9
[Modified by B18C-EJ1, 7:51 PM 12/30/2001]
Old Dec 30, 2001 | 06:50 PM
DragII's Avatar
25 Year Member
Default Re: Just removed power steering belt (B18C-EJ1)
leave the belt on.
Old Dec 30, 2001 | 08:00 PM
DR. ON POINT's Avatar
Banned
Default Re: Just removed power steering belt (MiGs)
only pussies have ps
Old Dec 30, 2001 | 08:01 PM
HT White Ops
Yeah, LID --- off the filter housing
Old Dec 30, 2001 | 08:13 PM
HT White Ops
Sorry, my bad! I should have said 4.1-HP to be exact. Forget the weight for now. That's a seperate issue...
Source: Import Tuner Magazine
Our tester came in with more than 100,000 miles on the odometer. We freshened the engine with a new set of plug wires, spark plugs and cap & rotor. Strapped to the dyno, the Civic pounded out 103.9 hp and 90.7 lbs-ft of torque.
Even though our tester had more than 100,000 on the ticker, the Civic was given the go ahead. Our first modification required only a 12mm wrench for power steering [belt - bdc] removal; removing the rubber hose from the intake box was performed in five minutes flat [removing the 'lid' from the filter housing will do the same thing -bdc]. Power figures jumped an astounding 4.1 hp and 2.9 lb-ft of torque, pushing our power level to 108.0 hp and 93.6 lb-ft of torque. Not bad for being free...
To put this in perspective:
Performance Chart
<u>Baseline Power: 103.9-HP</u>
Filter & Belt Removal: 4.1-HP gain
Thermal Exhaust 3.7-HP gain
PowerCore Header 7.7-HP gain
Final Power: 118.7-HP or 14.8-HP gain
As 'they' said, "Not bad for being free..."
[Modified by BlackDeuceCoupe, 9:27 PM 12/30/2001]
Old Dec 31, 2001 | 02:21 AM
ESCALVANTE's Avatar
If I remove everything under the Filter Housing (Resonator Box and Intake Head), will I trigger the CEL (check engine light)?
Has anyone done this? If so, does it make any change in sound or power?
TIA
Old Dec 31, 2001 | 07:50 AM
.nate's Avatar
Default Re: Just removed power steering belt (ESCALVANTE)
Put/Keep your power steering belts on until you get a non power steering rack in there.
Old Dec 31, 2001 | 09:24 AM
Crazydave's Avatar
TIA
No, I've done it... but my cone filter got too dirty too quick.. and was sucking hot air.. so I hooked the stock resonator and **** back up...
It makes your car have a loud deep throaty sound
I'm too cheap to spend money on an AEM CAI
Old Dec 31, 2001 | 09:42 AM
therealciviczc's Avatar
Default Re: Just removed power steering belt (KawiGreenVTEC)
What is the story on blowing the seals?
Isn't there something you can do.. like put the line back to itself of something strange. I feel like I've read that somewhere. My friend pulled his belt on his superbeater 1990 RS integra because he'll do anything for some laughs. It's pretty funny trying to steer the damn thinig in a parking lot. It's a piece. Anyway...
Old Dec 31, 2001 | 09:47 AM
Meth's Avatar
bdc are you serious man??? coz i know on sho you do this shiet but your really makin fun of the person
Old Dec 31, 2001 | 09:50 AM
DragII's Avatar
25 Year Member
Default Re: Just removed power steering belt (Squeeze)
please don't believe the garbage printed in import tuner magazine.
Old Dec 31, 2001 | 11:09 AM
HT White Ops
Default Re: Just removed power steering belt (TheFLY)
Your opinion...
My opinion: It won't hurt a thing!
Old Dec 31, 2001 | 11:36 AM
HT White Ops
Define "serious."
P/S units eat power and waste gas. That's why Honda is going to electric P/S on most of their 'new' cars. Do you think it's 'serious' in their minds?
Why does a 2500 lb. car need P/S anyway? It was answered nicely above; "P/S is for pussies," or more rightly 'soccer moms.' CiViCs are designed primarily for white female yuppies, not 'tuners.'
Secondly, while MY posts aren't to everyone's liking, most ppl say they enjoy them in my private mails, et cetera. I try to keep them interesting; "serious" but not 'too serious.' Example: Since you mentioned sho, I currently have a thread over there with 6600+ views and 400+ replies.
Think you'll ever see that kind of a thread on H-T? I could do the same thing here if the mods would quit 'locking' and 'moving' my threads...
UgandaHonda
May 25, 2011 10:41 PM
wdissident
Mar 19, 2009 02:05 PM
skcivic4life
64
Oct 30, 2007 06:05 PM
10K2HVN
Nov 8, 2002 05:39 PM
Comtechgsr2000s
Dec 2, 2001 05:52 PM
