Valve Ticking and SRS Light
JDM b16a in the car I am buying has some ticking... I believe all it needs is a valve adjustment. It runs great, compression is at 190 on all 4. Should I be worried about anything?
Also, the SRS light is on in the car. Any general ideas or precautions about this system? Any problematic issues?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMlyfestyle »</TD></TR><TR><TD CLASS="quote">my old car had a tick and i thought it was valves. 2 days later spun a bearing and through 2 rods through the block.</TD></TR></TABLE>
Wow.
What caused it then?
Also, misc. question: the cover on the timing belt has been hitting the hood - is this a common problem? How can that be fixed?
Wow.
What caused it then?Also, misc. question: the cover on the timing belt has been hitting the hood - is this a common problem? How can that be fixed?
the valve cover is hitting the hood? well im guessing its a crx with a b16? thats common for vtec swaps in rexes cause the USDM hood licks sack. Get a jdm ZC hood or cut the webbing under the hood that sits over the valve cover.
Its your lifters taping. not valves and sometimes tis a paint in the *** cause they just wear out and u have to replace this nut that is under them aint to hard at all but could just need adjustment. U can tell the difference in a knock and a click from a lifter..light click click as to knock knock
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 »</TD></TR><TR><TD CLASS="quote"> the valve cover is hitting the hood? well im guessing its a crx with a b16? thats common for vtec swaps in rexes cause the USDM hood licks sack. Get a jdm ZC hood or cut the webbing under the hood that sits over the valve cover.
Its your lifters taping. not valves and sometimes tis a paint in the *** cause they just wear out and u have to replace this nut that is under them aint to hard at all but could just need adjustment. U can tell the difference in a knock and a click from a lifter..light click click as to knock knock</TD></TR></TABLE>
It's definitely a clicking, not a knocking.
Also, it's a 92 CX.
Also, it's a 92 CX.
02_Si_FTW
Jul 17, 2008 03:32 AM
hatchedeg
Jan 26, 2006 03:11 AM
deconstruct
23
Jun 29, 2004 09:31 AM
