HELP!! ABS light on. k20a into dc2.
Old Nov 27, 2004 | 04:52 PM
TypeR0186's Avatar
Default HELP!! ABS light on. k20a into dc2.
I don't know why my abs light is on. What can i check to see if everyting is ok? i unplug the abs pump recently and plug it back up (just the plugs). it's all plug in now. i also took out the front brake rotor before it happen. Any idea how to fix this problem.. thanks...
Old Nov 27, 2004 | 05:32 PM
Katman's Avatar
Default Re: HELP!! ABS light on. k20a into dc2. (TypeR0186)
I think maybe, the axles you possibly used for your K20 swap do not have the metal ring around the outter joints (cups) which the ABS sensor needs to read from, which in turn will throw an ABS light.
Old Nov 27, 2004 | 06:42 PM
TypeR0186's Avatar
Default Re: HELP!! ABS light on. k20a into dc2. (K@man)
it does have a metal ring on the out side.
Old Nov 27, 2004 | 08:28 PM
v4lu3s's Avatar
RTFM
wy not check the ABS codes and see what is wrong?
Old Nov 27, 2004 | 09:59 PM
TypeR0186's Avatar
Default Re: (v4lu3s)
ohh and i don't have the link connector hooked up yet. if i try to read it by the check engine light blinking way it only reads "serial connector link" missing.
Old Nov 27, 2004 | 11:43 PM
v4lu3s's Avatar
RTFM
hrm maybe it is unhappy with the wiring being missing only then?
i know when my wifes lude had abs probloems i jsut put the jumper in and counter flashes on the abs light, though in her case it was a bad wheel speed sensor.
Old Dec 7, 2004 | 05:01 PM
6_GeArEd_TEG's Avatar
I am rockin an abs light in my k20 teg also.....???????????????????????
krazyk606
Jun 15, 2009 07:32 AM
dblas
Acura TL, RL & ZDX
Feb 23, 2007 02:40 PM
DC231_01
Jun 26, 2006 08:37 PM
Scither69
Jun 9, 2004 09:19 PM
