Turbo location....left or right?
Old Nov 27, 2004 | 04:34 PM
NVturbo's Avatar
O.G. triple O.G.
Default Turbo location....left or right?
I have noticed that some people have installed their turbo setups with the compressor on the right and the turbine on the left. I know that the downpipe flow is shorter and straighter along with the shorter IC piping flow(compressor to FMIC). Does this make any more HP/TQ than the common setups? I do like the more aggressive look with the turbocharger being more "exposed". Plus, I do noticed that the surrounding clearance is not too bad. I don't have A/C nor power steering in my car so the space in front of the timing belt is pretty adequate. Let me know of your opinions/comments. Thanks in advance.
Old Nov 27, 2004 | 04:50 PM
MooreBoost's Avatar
Default Re: Turbo location....left or right? (NVturbo)
My compressor is on the drivers side. Short IC piping, short downpipe.
Edit- and those two things result in more throttle response.
Old Nov 27, 2004 | 05:30 PM
nonvtecD's Avatar
Default Re: Turbo location....left or right? (tegunderpressure)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegunderpressure &raquo;</TD></TR><TR><TD CLASS="quote">My compressor is on the drivers side. Short IC piping, short downpipe.
Edit- and those two things result in more throttle response.</TD></TR></TABLE>
Same here
Old Nov 27, 2004 | 06:00 PM
sporkcrx's Avatar
Default Re: Turbo location....left or right? (D15B7turbo)
I like it like that because it makes everything less clutered, and you dont have a downpipe right by your oil drain
Old Nov 27, 2004 | 06:01 PM
Muckman's Avatar
Moderator in Chief
Default Re: Turbo location....left or right? (sporkcrx)
but you cant run ac that way
Old Nov 27, 2004 | 06:03 PM
adseguy's Avatar
I think the only reason put the compressor on the passenger side is to clear A/C...otherwise it's so much easier to just put the compressor on the driver's side. Since you don't have A/C, i'd say do it the easy way even though the difference in HP is probably (I haven't seen studies) minmal.
Old Nov 27, 2004 | 06:04 PM
hondaguyef's Avatar
I thought I was all alone
Phil
Old Nov 27, 2004 | 06:05 PM
UberTeg's Avatar
Default Re: Turbo location....left or right? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">but you cant run ac that way </TD></TR></TABLE>
Yes you can. My obx manifold lets me have a/c with my compressor on the driver side. Doesnt let me have a full size radiator tho, heh.
Old Nov 27, 2004 | 07:07 PM
EJ1 wilcox's Avatar
Default Re: Turbo location....left or right? (UberTeg)
I like it on the passenger's side because I don't have enough room to run a filter the other way... because I have power steering...
Old Nov 27, 2004 | 07:47 PM
5thgencivic's Avatar
Default Re: Turbo location....left or right? (adseguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">I think the only reason put the compressor on the passenger side is to clear A/C...</TD></TR></TABLE>
Or if you can't rotate the compressor housing because of the wastegate actuator like on the GT28R for example.
Old Nov 27, 2004 | 08:04 PM
adseguy's Avatar
Default Re: Turbo location....left or right? (5thgencivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5thgencivic &raquo;</TD></TR><TR><TD CLASS="quote">
Or if you can't rotate the compressor housing because of the wastegate actuator like on the GT28R for example.</TD></TR></TABLE>
Thanks! Gotta learn somethin every day
Old Nov 27, 2004 | 08:34 PM
mattcalica's Avatar
i am running mine, compressor facing drivers side...A/C is overrated, thats what the wind is for.
Old Nov 28, 2004 | 06:38 AM
MooreBoost's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adseguy &raquo;</TD></TR><TR><TD CLASS="quote">even though the difference in HP is probably (I haven't seen studies) minmal.</TD></TR></TABLE>
Horsepower shouldn't be effected either way. Throttle response/turbo response is what should be effected.
Old Mar 27, 2005 | 05:00 PM
darkdayz's Avatar
Default Re: Turbo location....left or right? (MooreBoost)
like moore boost stated response is what is affected the most this way(with lessic piping
Old Mar 27, 2005 | 05:05 PM
flip1199's Avatar
Default Re: Turbo location....left or right? (darkdayz)
i'm running mine with the compressor on the passengers side. mainly because i have a prelude and it works best with my setup. and i have probably the shortest length i/c piping here.
Old Mar 27, 2005 | 05:39 PM
turboEGhatch's Avatar
Default Re: Turbo location....left or right? (flip1199)
Having a foot less intercooler piping really doesn't do anything for improving throttle response, do you know how fast the air is moving in your charge pipes?
Topdawgg
May 17, 2007 11:28 AM
ityab0y
Nov 7, 2005 04:44 PM
jdm-ray
Sep 8, 2005 09:45 AM
BoOsTiN Dc2
Apr 8, 2005 04:05 AM
MayhemSi
May 7, 2004 06:49 PM
