ECU harness gone to HELLLLLL!!!!!!!!!!!!!!!
Old Nov 27, 2004 | 02:46 PM
D3U1LT's Avatar
Default ECU harness gone to HELLLLLL!!!!!!!!!!!!!!!
HELP! ecu was cut from harness at the plugs a while back. I tried to re-wire the harness the cell light is solid while checking it and the car does not run worth **** hella rich and boggy. started to get a harness out of another car...... HHEEEEEEEEEEEEEElllllllllllllll no! wasnt happening.
I guess my ? is what do i do now the ej is fucked!!!
Old Nov 27, 2004 | 02:49 PM
john d
Guest
Posts: n/a
Default Re: ECU harness gone to HELLLLLL!!!!!!!!!!!!!!! (EJ1Racing.tk)
cry about it and post it on h-t
Old Nov 27, 2004 | 02:53 PM
D3U1LT's Avatar
Default Re: ECU harness gone to HELLLLLL!!!!!!!!!!!!!!! (john d)
great help... coool guy!
mzboy's Avatar
Sounds like your on the right track with getting a harness out of another car.
Old Nov 27, 2004 | 02:59 PM
D3U1LT's Avatar
Default Re: ECU harness gone to HELLLLLL!!!!!!!!!!!!!!! (mzboy)
the car was a wrecker and i gave up, Have to take all the dash and heater and **** what a pain...
Old Nov 27, 2004 | 03:14 PM
D3U1LT's Avatar
anything else i can do please help!!
Old Nov 27, 2004 | 05:11 PM
D3U1LT's Avatar
bump for help!
Old Nov 27, 2004 | 05:34 PM
TGrant's Avatar
the reason rewiring didnt work is because the resistance was changed in the wires
only thing you can do is swap in a harness
i no its a pain but if you ever want your car to run right again youll have to
Old Nov 28, 2004 | 01:56 PM
D3U1LT's Avatar
Bump for alternatives!
Old Nov 28, 2004 | 02:06 PM
revvin9k's Avatar
Well the same thing happened to me in my Sol. I was removing the wiring for my ABS system and somewhere in the mix I messed up the harness. I was lucky and found one on ebay for $100.00 in perfect condition with the clips still intact. Your only other option is to go source another one.
Spawne32
Feb 24, 2012 04:10 PM
Naudlee
17
Aug 14, 2006 06:25 AM
ch00dlz
Jul 24, 2006 09:18 PM
Superhatch
Jul 10, 2002 04:37 AM
