will d series axles fit 96 itr suspension?
will the d series axles fit 96 itr suspension? are there any differences in axle diameter between manual and automatic axles.
thanks
thanks
the outer splines are the same however the lengths and the inner CV joint splines are either 2 or 4 mm to small. they will not work you should use the ITR axles or looka t getting some custom lengths made by someone like Driveshaft shop
becauseracecar8
12
Jul 2, 2014 10:17 AM
Cap'N Chronic
May 24, 2011 06:08 PM
dpine
Nov 28, 2004 01:03 PM
