95 ls motor in EK
Will this plug into the obd 1 motor?? What will i need to change. I know i need shift linkage, headers, motor mounts, axles?? If you could let me know what else i need i would appreciate it. And I was told that turbo will cancel out vtec?? Is it worth it to have vtec on turbo setup. Thx
if your talking "ek" as in 96-00, then you are in the wrong forum, in which that would also make your car obd2 not obd1. meaning that a 95 or obd1 swap will not work without a conversion harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon.eg »</TD></TR><TR><TD CLASS="quote">Will this plug into the obd 1 motor?? What will i need to change. I know i need shift linkage, headers, motor mounts, axles?? If you could let me know what else i need i would appreciate it. And I was told that turbo will cancel out vtec?? Is it worth it to have vtec on turbo setup. Thx</TD></TR></TABLE>
Turbo cancels out vtec??...You can't be that retarded..
The 99-00 SI b16 is the only b-series motor that bolts in ..
Theres a big FAQ thread in the forum that has swap tech..Go look in there
kyle1jzsupra
Aug 29, 2008 02:57 PM
Samuels
Apr 8, 2006 10:34 PM
