Skunk2 IM worth it?
Old Dec 29, 2001 | 10:41 PM
speedymon's Avatar
Default Skunk2 IM worth it?
I'm getting a CTR intake cam, so is it worth it since these aren't that aggressive? Any significant hp gains or stick with the stock IM?
Old Dec 29, 2001 | 11:07 PM
court's Avatar
25 Year Member
Default Re: Skunk2 IM worth it? (speedymon)
with my friends gsr motor, he installed the junk 2 mani when it first hit the market to compliment his itr valve train and cams. on the butt dyno, he said the gain was incredable.
from another person, whom went to the dyno, he stated that the junk2 mani tossed up a big doughnut
i say its a piece of ****, quality and name. port the p73, i think you will be much more happier with it
Old Dec 30, 2001 | 12:24 AM
rainforest's Avatar
Default Re: Skunk2 IM worth it? (court)
type r's are much nicer i think. if you have a gsr get a skunk 2 allways, bit for a i/h/e b16a a type r mani is kinda big once you get cams or high comp pistons is when you see a gain with a itr.
Old Jan 1, 2002 | 07:03 AM
JCushing's Avatar
Default Re: Skunk2 IM worth it? (rainforest)
i coulda swore that skunk itm are copys of the typr r manifold just ported a little bit extra. the runners are much shorter than on your stock one btw. i noticed a difference but i have a gs.....
Old Jan 1, 2002 | 08:44 AM
Tweakmeister's Avatar
Default Re: Skunk2 IM worth it? (JCushing)
Stock, the Sk IM will loos some mid-range and give some top-end. (dynoed)
It's an ITR IM copy, and will require some work to make it fit usually.
Mase
Dec 14, 2005 04:06 PM
nhsk84life
Nov 4, 2005 05:51 PM
12secteg
Oct 14, 2005 06:04 AM
maggsgsr
Jan 25, 2002 12:46 PM
B18C-EJ1
Jan 20, 2002 04:24 PM
