Why isnt my car revving?
Old Nov 26, 2004 | 06:38 PM
Leks's Avatar
Default Why isnt my car revving?
I just turbocharged my car but it wont rev past 4500 when boosting. It feels like its leaning out so I changed my fuel pump. I put a walbro 255 in it. But still nothing. My setup is a b16, T3/T4 turbo, turbonetics evo wastegate, fmu with stock injectors and the fuel pump. If anyone has any info please let me know.
Old Nov 26, 2004 | 06:42 PM
98lude-t's Avatar
Default Re: Why isnt my car revving? (Leks)
alrighty u have any fuel management or map fix anything other than what you said?
Old Nov 26, 2004 | 09:33 PM
CRXdan's Avatar
sounds liek a map sensor issue because of no missing link
Old Nov 26, 2004 | 09:44 PM
TurboCoop's Avatar
Default Re: (CRXdan)
I will sell you my missing link for $40.00.
Old Nov 27, 2004 | 12:19 PM
skivik's Avatar
im having the same problem with the turbonetics kit
Old Nov 27, 2004 | 12:21 PM
skivik's Avatar
Default Re: Why isnt my car revving? (skivik)
but i have, fuel managment, had it on a dyno, new fuel pump injectors, closed the gap on the spark plugs
msd ignition it has been getting better but not perfect....
Old Nov 27, 2004 | 02:25 PM
hybridsol's Avatar
Fuel management = hondata or Uberdata or AEM...
-or-
AFC hack
-or-
FMU + missing link for MAP sensor
Which one?
Old Nov 27, 2004 | 02:27 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: Why isnt my car revving? (hybridsol)
any cel's? maybe the car is trying to go into limp mode for some reason.
Old Nov 27, 2004 | 07:54 PM
skivik's Avatar
thats what i was thinking that maybe that knock sensor is picking up some vibration or somthing like that i was told how to put rubber around the knock sensor to make it not pick up vibration as easy, idk tell me what you think
Old Nov 27, 2004 | 08:06 PM
Calvinator's Avatar
Check your plugs..see if your leanning out after 4500...
Old Nov 27, 2004 | 08:08 PM
skivik's Avatar
Default Re: Why isnt my car revving? (xtremeazian)
i have had my car on the dyno and it leans out a lil bit aroud vtech but only for a couple of 100 rpms
Old Nov 27, 2004 | 09:17 PM
Calvinator's Avatar
hurry and Edit your vtech to VTEC!! before it gets bad.
Old Nov 27, 2004 | 09:19 PM
Calvinator's Avatar
Did this started happening right after the dyno or out of nowhere? Also, how much psi are you running on ur set-up?
Old Nov 27, 2004 | 09:31 PM
skivik's Avatar
it happened rght after the dyno it was fucked up
Old Nov 27, 2004 | 09:43 PM
DRIVENRacing's Avatar
get 450's and do afc hack...
Old Nov 28, 2004 | 10:17 PM
skivik's Avatar
i have the bigger venom injectors and the fuel managment that came with the turbonetics kit
shanepa2001
Jun 23, 2006 11:48 AM
hotimportcrx
Jul 14, 2005 02:06 PM
drLazy
Dec 10, 2003 04:32 PM
Mr.Saturn
Apr 8, 2003 11:50 AM
SPEED123
Jul 11, 2002 06:52 PM
