front cross member bracket mount....
Old Nov 26, 2004 | 04:12 PM
jdub db8's Avatar
Default front cross member bracket mount....
Do i need to remove it to get this b18b1 into a crx? I am guessing i do since it won't go in otherwise?
Old Nov 26, 2004 | 04:24 PM
Bserieskllr's Avatar
Default Re: front cross member bracket mount.... (Jester_Si)
you can just beat the crap out of it to bend it out of the way too.
Old Nov 26, 2004 | 05:31 PM
Mr_CRX's Avatar
It depends on what mount kit you have. I have AZ Race & Machine mounts and I didnt need to remove that mount. (I removed the crossmember while the engine was being installed and then reinstalled it) If you dont remove the front cross member, it can be a pain to get the motor maneuvered around that mount.
I used to have some crappy no-name mounts and I had to hack that mount off.
Your best bet is to take the whole front crossmember off, install the engine and then reinstall the crossmember and see if it needs to be removed or not.
Old Nov 26, 2004 | 05:45 PM
2point2's Avatar
do it right.
take off the crossmember, drill out the 'tacks/welds' and then hammer the mount off. it will like very clean.
Old Nov 26, 2004 | 07:25 PM
jdub db8's Avatar
Default Re: front cross member bracket mount.... (2point2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">do it right.
take off the crossmember, drill out the 'tacks/welds' and then hammer the mount off. it will like very clean.</TD></TR></TABLE>
This is what i did. Thanks Guys!
Old Nov 26, 2004 | 08:27 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jester_Si &raquo;</TD></TR><TR><TD CLASS="quote">This is what i did. Thanks Guys! </TD></TR></TABLE>
good stuff..
Old Nov 26, 2004 | 09:30 PM
NikoZai's Avatar
yeah cut it off if you want or get a jimfab x-member. either way, its not a big deal, when you pull the engine out to do the swap, just get in there with a sledge and a cutter. Dont forget alternator clearance. It also depends on the mounts you use.
Luke G.
Mar 14, 2010 11:53 AM
code47mastermind
Dec 8, 2007 01:21 PM
Amused
Apr 2, 2007 07:45 PM
Project_EK
Jun 2, 2006 07:06 AM
JDM-EJ1
Aug 1, 2005 12:10 PM
