would a centerforce dual friction hold 10 psi of boost?
Old Nov 26, 2004 | 03:36 PM
iNetForce's Avatar
Default would a centerforce dual friction hold 10 psi of boost?
guys I have a 88 crx with a d16z6 swap, I have a 91 si tranny so im running a 91 clutch, i was wondering if I a centerforce dual friction clutch kit would hold 10 psi on this engine, i dont want the clutch to be a problem, i was thiking of the act heavy diuty presure plate and performance street disc, but only the pp and the disc are more expensive than the whole centerforce dual friction clutch kit.
let me know what u guys think about the dual friction pls, thanks in advance.
Old Nov 26, 2004 | 03:38 PM
DocSean's Avatar
Default Re: would a centerforce dual friction hold 10 psi of boost? (iNetForce)
10psi from what turbo? Any other bolt-on's? You'd be better off telling us what your HP goals are.
Old Nov 26, 2004 | 04:29 PM
dr_latino999's Avatar
Default Re: would a centerforce dual friction hold 10 psi of boost? (spankjelly)
Or in perspective torque numbers.
Old Nov 26, 2004 | 05:53 PM
mrspeaker's Avatar
Default Re: would a centerforce dual friction hold 10 psi of boost? (dr_latino999)
10psi isnt the same with every turbo..
You can have a t25 at 10psi pushing 180hp...or you can have a 60-1 at 10psi pushing 400hp..
Old Nov 26, 2004 | 08:36 PM
iNetForce's Avatar
Default Re: would a centerforce dual friction hold 10 psi of boost? (Mrspeaker)
its a 14b, close to 200whp, i dont know about torque
Old Nov 27, 2004 | 10:03 AM
DocSean's Avatar
200whp....you could use the exedy organic if you wanted too.
Old Nov 27, 2004 | 10:54 AM
iNetForce's Avatar
im not currently carrying exedy so i cannot get it as cost, im only carrying act and centerforce.
Old Nov 27, 2004 | 11:38 AM
DocSean's Avatar
ANY aftermarket clutch will be able to support 200hp, you will have no problem running either.
BitterTrigger
Dec 29, 2011 09:52 PM
EKway2low
Jun 10, 2008 09:38 PM
donkiman
Jan 19, 2005 06:08 PM
iNetForce
Apr 3, 2004 03:59 PM
B18poweredhatch
Feb 25, 2002 12:17 PM
