wich clutch for ls boost???
Old Jun 3, 2008 | 11:48 PM
EKway2low's Avatar
Default wich clutch for ls boost???
hey im boosting my eg with ls swap pretty soon and im just looking for some advise here so i would like to hear from people that actually has/had them clutches to be able to tell me how it holds and feels....i know there is alot to choose from...i dont want anything toooo agresive since its my dd and im only boossting 7-10 psi ant the most.... thanks.....
Old Jun 3, 2008 | 11:51 PM
Jimmy's Avatar
Global Moderator
A nice clutch kit will prove vital in your setup..
I do not recommend cheaping out and getting a clutch kit from ebay.. I've seen to many threads with problems, and experience my self from XTD clutch kits, and grip force..
If you can afford it i suggest you use either or..
ACT HDSS
ACT XT-SS
Depending on WHP/TQ goals
Act clutch kits come with throw out beating, clutch plate alignment tool and i believe a pilot bearing..
You can not go wrong with purchasing a ACT clutch kit... Also EXEDY & clutch masters are good companies.
Old Jun 4, 2008 | 12:10 PM
inspyral's Avatar
I'm running a Clutch Masters Stage 3 and an ACT ProLite flywheel. Engagement is like stock, and it holds well at 11psi. No complaints whatsoever.
Old Jun 10, 2008 | 09:38 PM
EKway2low's Avatar
Default Re: (inspyral)
ok so i just got my fidanza 8lb flywheel and im still not sure what clutch to get for it i was thinkin of getting the clutchmasters fx300 (stage 3). but i wana hear more from u guys who have different set ups remember im only boosting 10-12 psi at the most.. thanxs
BitterTrigger
Dec 29, 2011 09:52 PM
s2k_8582
Honda S2000
Jul 20, 2011 12:09 AM
siblue_gzer
Mar 11, 2005 11:58 PM
UpstateCivic
Apr 15, 2004 08:19 AM
SIK IN DA HED
Sep 11, 2001 09:17 AM
