bad gas = limp mode?
Old Nov 26, 2004 | 12:55 PM
Spyglass's Avatar
New User
Default bad gas = limp mode?
Is it possible that a bad tank of gas could cause the car to go into limp mode (no vtec)?
I filled up recently, the car sputtered a few times leaving the gas station, and was in limp mode for a while, everything else running fine (I guess). It has since come back (vtec), however, and I am wondering what the hell was going on.
Modified by Spyglass at 1:30 AM 11/27/2004
Old Nov 26, 2004 | 01:06 PM
sneakychaos's Avatar
Default Re: bad gas = limp mode? (Spyglass)
Check your oil level?
Old Nov 26, 2004 | 01:50 PM
Chris93Si's Avatar
Did you get a CEL? If no I'd guess low oil level
Old Nov 26, 2004 | 04:28 PM
Spyglass's Avatar
New User
Default Re: bad gas = limp mode? (Chris93Si)
Yes, the oil level was ok. I always have a CEL because of a straight pipe, so that's nothing new.
Old Nov 26, 2004 | 04:31 PM
uNF$@#!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spyglass &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the oil level was ok. I always have a CEL because of a straight pipe, so that's nothing new.</TD></TR></TABLE>
so you know what the problem is then.
Old Nov 26, 2004 | 04:50 PM
s2kdre's Avatar
Default Re: bad gas = limp mode? (255.255.255.255)
the secondary o2 does not cause it to go into limp mode. It reads the air/fuel from the primary o2.
Old Nov 26, 2004 | 05:53 PM
Chris93Si's Avatar
Default Re: bad gas = limp mode? (jdmhonda)
I'd check your CEL to see if something new is coming up
Old Nov 26, 2004 | 06:14 PM
Rhetoric's Avatar
Possibly your primary o2 is bad. I had a similar problem with terrible gas mileage and irregular idling and found that my o2 was the problem.
venomzz
28
Dec 14, 2007 05:44 AM
DanielCarswell
Dec 13, 2007 12:59 PM
twistedgsr
Mar 19, 2007 08:31 PM
si0385.
Dec 8, 2005 08:18 PM
redline201
14
Nov 7, 2003 08:22 PM
