oil smells like gas
oil smells like gas
i noticed my oil smelled like gas
i change the oil
drove it for a half hour
smells like gas again
WTF is wrong
can it be from running rich?
i change the oil
WTF is wrong
Re: oil smells like gas (redline201)
They both live in the same engine. It's normal. Think about it.
EDIT: please disregard my misinformation.
Modified by mycivicstoo(s)low at 11:43 PM 11/6/2003
Re: oil smells like gas (mycivicstoo(s)low)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low »</TD></TR><TR><TD CLASS="quote">They both live in the same engine. It's normal. Think about it.</TD></TR></TABLE>
Um, no.
You live in a house with a toilet. Do you smell like ****?
Sounds like you are running really rich, and are getting a lot of blowby, due to your rings failing, and not sealing properly.
How many miles do you have? Might want to do a compression/leakdown test. Check your plugs to see if you are rich...
Um, no.
Re: oil smells like gas (Revolveu2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolveu2 »</TD></TR><TR><TD CLASS="quote">
Um, no.
LOL, nice analogy.
Um, no.
LOL, nice analogy.
too much fuel can be a cause of this.....if you having a problem with too much fuel then you should look into it. also do these 3 things and you will be set...
1. compression test.
2. leakdown test.
3. fix the runinng rich problem (if you have one)
let us know what you get from the tests
2. leakdown test.
Re: oil smells like gas (80884)
I didn't think he meant a strong smell. Now that I think about it, my oil doesn't smell too much like gas when I drain it. I was recalling when I pulled the valve cover and smelled gas in there with the little bit of oil. I was a little tipsy when I wrote that before, I'm a retard.
Oh yeah, the toilet line was great.
Modified by mycivicstoo(s)low at 12:13 AM 11/7/2003
Um, no.
You live in a house with a toilet. Do you smell like ****?</TD></TR></TABLE>lafao,almost fell out of the chair.Now this guy's problem.Yes your running to rich,as a result you probably fuel washed the cyl walls,and may have ruined the rings if it went on long enough.
Um, no.
It's obvious I don't know what's going on here. So maybe I have the same problem. I don't blow smoke either, and the gas smell is very vague in my case.
well it turns out one of my sparkplugs stoped firing
and im running rich
everything else seems ok
so no 1.8 block upgrade for me
thanks for your help fellas
and im running rich
Re: oil smells like gas (Dimi)
i would have suggested broken head gasket. glad you found the problem.
EDIT: if one of your spark plugs wasnt firing, you would've thrown a code. did you?
Um, no.
ahahah funny ****
Um, no.
ahahah funny ****
msinsky14
12-10-2007 05:05 PM
