vafc installation walkthrough
Old Nov 26, 2004 | 12:36 PM
b18c1995's Avatar
Default vafc installation walkthrough
Does anyone know where to find an online walkthrough of a vafc install? I can understand the directions, but im more of visual learner and it would be great to a have a walkthrough so i dont mess anything up.
Old Nov 26, 2004 | 03:26 PM
sabotage7's Avatar
Default Re: vafc installation walkthrough (b18c1995)
bump, cuz i'd like the answer too cuz im getting my friends vafc and i dont think he has the directions!
Old Nov 26, 2004 | 04:42 PM
IN VTEC's Avatar
http://www.apexi-usa.com
It's in the documentation available for download.
The wires you have to tee into are:
tach signal wire for rpm reading
TPS wire for throttle position reading
+12VDC power wire
(x2) brn/blk ground wires - one of them has to be closer to the ECU
The wires you have to wire the VAFC in series with (so the VAFC can intercept and alter the signal before it hits its target):
VTEC solenoid wire
MAP sensor wire
Other:
VTM wire gets cut and taped off.
If you have a VAFC-II, then you'll also need to tee into the knock sensor wire.
If you're good at soldering cleanly, I'd do that and heat shrink the connections. If not, then use the wire splices. Even if the wire splices are more of a liability than a good solder connection, a bad solder joint can be just as bad. Do what you're more comfortable with.
Old Nov 26, 2004 | 05:59 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
Default Re: vafc installation walkthrough (IN VTEC)
http://www.b-series.net
Old Nov 26, 2004 | 07:02 PM
BlueIntegraBoy's Avatar
Does the VAFC reset if you undo the negative terminal of the battery?
Old Nov 26, 2004 | 07:06 PM
Default Re: vafc installation walkthrough (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Does the VAFC reset if you undo the negative terminal of the battery?</TD></TR></TABLE>
no
blk_db2's Avatar
no.... you have hit initialize on etc. to do that...
Old Nov 26, 2004 | 09:11 PM
b18c1995's Avatar
thanks for the help, b-series.net seems to be down, or a broken link. Anyone know where i can go for a pictorial walkthrough maybe?
Old Nov 27, 2004 | 12:51 AM
A_RU_BA's Avatar
Default Re: (b18c1995)
the apexi site has one. just make sure u have adobe so u can dl the manual n etc.
pretty easy install, just tapping a few wires n spliccing 2. no less than 30minutes if u know where n what to do
Old Nov 27, 2004 | 01:03 AM
Sack Master's Avatar
Default Re: (A_RU_BA)
Yeah just get the instructions off thier site. It's really not that hard at all.
EJ1 wilcox
Jun 7, 2004 09:33 AM
racinskittle
Sep 27, 2003 09:44 PM
Type RS
Feb 5, 2003 02:27 AM
FUP23
Sep 17, 2002 04:44 PM
