>>> HOMEGROWN TURBO SET UPS - - Whatcha Got?
Old Nov 25, 2004 | 06:29 PM
dimotorsports's Avatar
Default >>> HOMEGROWN TURBO SET UPS - - Whatcha Got?
Have any of you out there got a homegrown turbo set up?
For Example: a Volvo turbo with a HF mani, or a Eclipse turbo with a custom mani, etc.
Tell us what you've done..
Pro's? Cons? Etc...
Pix too if you've got'm!
Old Nov 25, 2004 | 06:46 PM
PrettyLude's Avatar
homemadeturbo.com
Old Nov 25, 2004 | 08:46 PM
stealthmode62's Avatar
Default Re: (PrettyLude)
My last setup was a d16y8 with
Ford Thunderbird turbo
Saab downpipe flange
Mitsu injectors and blow off
everything else was custom
Junkyard racers
Old Nov 26, 2004 | 12:48 AM
hurleyboarder21's Avatar
Default Re: (stealthmode62)
my buddy and i had one on a d16a6. it had 3 different setups.
1. t25 <----died up top
2. t3/t4<----way to big for my liking (custom mani)
3. 14b <----20psi...oooopps.
we had each of those turbos with...
hf mani
custome adapter plate
ghetto *** ic piping
1st gen dsm bov
johnnyracecar ic
dsm 450's
and all street tuned with turbo edit
that **** ripped for what it was. we spent a little over 300 bucks, and it was fun as hell. i just helped my other buddy finish is hmt zc, and that thing is faster than the other setup. hmt...
Old Nov 26, 2004 | 12:51 AM
Default Re: (hurleyboarder21)
t25 setup:
http://www.homemadeturbo.com/f...29623
hole in block:
http://www.homemadeturbo.com/f...31183
Old Nov 26, 2004 | 04:46 AM
hondaguyef's Avatar
SSauto mani
Garrett TA3107 (2.3 L perkins/John deere Diesel turbo)
Universal exaust flange (for tractor use )
2.5 Down pipe (from the tractor)
The Ta3 dies up top but, it get the job done! See sig.
Phil
Old Nov 26, 2004 | 05:40 AM
USDM 4G VTEC's Avatar
HF manifold ported
14B turbo
My own custom adapter plate
Old Nov 26, 2004 | 06:23 AM
scttydb411's Avatar
d16y7
td04L off a wrx running 10-13psi
std/hr manifold with adapterplate i made
dsm 450cc inj and honda resistorbox
dsm bov
jc whitney mandrel ubends for chargepipe and hacked aem cai
starion fmic w/ custom in/outlets
y8 intake manifold and throttlebody
mbc-homemade bleeder style
uberdata
pros:
way faster than stock
cons:
none yet after 1.5 years and 31k+ miles
Old Nov 26, 2004 | 06:27 AM
The Hooligan's Avatar
From: spinning DnB till your head explodes,jersey/philly
Default Re: (scttydb411)
standard manifold
mx-6/probe turbo
mx-6 front mount intercooler
saab and volvo piping
vafc
dsm 450s
2.25 exhaust with a gutted cat
i did the whole kit including the price for the injectors and vafc for under $400
Old Nov 26, 2004 | 06:58 AM
rudebwoy's Avatar
Default Re: (91siredrex)
95 civic fully built b16a
9.0.1 compression JE pistons
eagle h beam rods
GE block guard
ARP head studs
cometic head gasket
mild port and polish head
kms valve springs,titanium retainers
JG edelbrock manifold
JG engine dynamics 65mm tb
uberdata p28
zeitronix wideband
autometer egt ,oil and boost gauge
RC 750cc injectors
GM 3 bar map sensor
walbro 255lph fuel pump
Aem fpr+rail
Garret t3/t4 turbo
Custom coach intercooler
2.5" custom piping
ssauto **** manifold
35mm wastegate/dump tube
custom 3" dp, catback
blitz ss bov
turbo xs mbc
nitrous express ntercooler
nitrous xpress efi fogger kit
type R lsd
exedy stage 2 clutch
exedy 8 lbs flywheel
msd 6a and coil
all parts installed by me
all piping fabbed and welded be me
all chipping done by me
things left to do: break the engine in
tune the ecu
all HOMEMADE TURBO and no ghetto ****... still more to come I will post pics when I return from Iraq and paint the car and finish interior. I am the reallest DIYer
PROS. you save a lot of money you get to do everything yourself, so when someone ask you about you engine you dont have to guess, plus you learn as you go, plus make you proud of your work.
CONS: if you dont do it right the first time you lose money, and you wont have warranty on the work.
but either way I will never pay another mechanic to do the same thing I can do... reseach and you can do anything... HMT, UBERDATA FORUM, PGMFI its all in your face. and always remember HMT owns all forums
Modified by rudebwoy at 4:49 PM 11/26/2004
Modified by rudebwoy at 2:49 PM 11/27/2004
Old Nov 26, 2004 | 07:15 AM
mattEG's Avatar
95 Civic Hatch
Stock Internal D15B7
Mitsu TEO4H off a Caravan @ 7psi
Homemade Boost Controller
Custom Log Manifold (c-zero)
DSM450's
2.5" charge pipe
DSM SMIC
Uberdata! :D
Old Nov 26, 2004 | 09:31 AM
300whpOrBust's Avatar
Default Re: (mattEG)
Quick question, a local guy here is selling a 14b, where do they top out hp wise on a d16y8 with an hf manifold?
Old Nov 26, 2004 | 03:59 PM
Default Re: (300whpOrBust)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 300whpOrBust &raquo;</TD></TR><TR><TD CLASS="quote">Quick question, a local guy here is selling a 14b, where do they top out hp wise on a d16y8 with an hf manifold?</TD></TR></TABLE>
check my signature
got pics and **** from my dyno
Old Nov 26, 2004 | 05:47 PM
CSaddict's Avatar
Default Re: (USDM 4G VTEC)
96 CX hatch
00 Y7 stock
Y8 tranny
6 puck clutch specialties
Y8 intake
Saab 48/42 T3 turbo
Manifold made by me
Charge pipes made by me
Converted to OBDI
Chipped P06 using Uberdata by me
5" Johnny racecar intercooler
MBC made by me
Pros= More than doubled power to ground for less than $1000
Cons= stock clutch= owned!
Old Nov 26, 2004 | 08:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">check my signature
got pics and **** from my dyno</TD></TR></TABLE>
btw heres a copy of my dyno sheet
Old Nov 26, 2004 | 08:40 PM
Davep's Avatar
Default Re: >>> HOMEGROWN TURBO SET UPS - - Whatcha Got? (dimotorsports)
Here's a set up I made out of a turbocoupe T3. I made the manifold, downpipe and dumptube for it.
I'm selling this set up BTW.
Modified by Davep at 11:32 PM 11/29/2004
Old Nov 26, 2004 | 09:09 PM
Built B16A's Avatar
From: hittin corners so hard you can taste my rims..
Default Re: >>> HOMEGROWN TURBO SET UPS - - Whatcha Got? (Davep)
i think we need to start see'ing some of these HMT .bin files for the Uberdata users..
i have a P28 here chipped.. ready to step up the management a notch.
D15Z1.. lol, yes a VX.
T25 @ 6-7 PSI
eBay BOV
log style manifold
6" tyrus FMIC
2.5" custom downpipe
UNI dirtbike air filter.
so now i have a EGT installed, and resently a PLX M300, and some DSM 450's on the bench... im ready for uberdata...
Old Nov 26, 2004 | 09:36 PM
CRXdan's Avatar
89 d16a1
IHI RHB%
00 dx manifold
DSM BOV
yadda yadda yadda
Old Nov 26, 2004 | 09:54 PM
imthedude's Avatar
94 gsr
holset hx35 off of dodge ram
rev hard mani
evo front mount
custom charge pipe
tial bov
tial 38mm wastegate
custom 3in down pipe
dsm 450s
Old Nov 27, 2004 | 12:11 AM
Jockobo's Avatar
Default Re: (imthedude)
here's my old homemade set up
d16_vtec
Nov 28, 2008 11:32 AM
atmosphere
Jul 25, 2005 01:59 AM
Doug684
Jan 12, 2005 11:32 AM
project142
Sep 19, 2003 08:12 AM
del_sol
Oct 31, 2002 09:50 AM
