si lsd w/ gsr tranny
Old Nov 25, 2004 | 01:54 PM
cluelessmale's Avatar
Default si lsd w/ gsr tranny
I order the wrong LSD I got the Si tranny one and not the GSR one. From what I read so far both trans have a 4.4 FD. Can I just use a Si ring gear?
Old Nov 25, 2004 | 02:52 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: si lsd w/ gsr tranny (cluelessmale)
The ring gear would be the same if they both have a 4.400 final drive. I'm surprised that the two LSD's aren't the same part number.
They should work on both vehicles.
EDIT: When I was messing with putting a Type R LSD into my LS tranny, I had to mess with swapping out countershafts and ring gears. I had several to work with and I noted that the Si one and the GSR one were the same. I think I just picked the GSR one and used that. I also used an Si countershaft. Seems like the Si and GSR parts are interchangeable. The gearing is different, but the final drive ring gear and countershaft seem to be the same. I don't know about the mainshaft, but that isn't important in your case.
Old Nov 25, 2004 | 02:58 PM
Default Re: si lsd w/ gsr tranny (shamoo)
Yea that is what i thought but the bolts to not line up, the hole in the LSD are closer then the ones on the ring gear.
Old Nov 25, 2004 | 03:27 PM
what you push the ring gear to one side of the lsd you have like a 1/4 inch grap.
Does the Si ring gear have a smaller inner dimameter
Old Nov 25, 2004 | 08:42 PM
stumpyf4's Avatar
Ring gears are different, GSR and ITR are the same and SI and LS are the same. You need a LS or SI ring gear.
Old Nov 26, 2004 | 11:47 AM
Default Re: si lsd w/ gsr tranny (stumpyf4)
Si and LS are different Si is a 4.4 and the LS is not
Old Nov 26, 2004 | 06:51 PM
integramic's Avatar
Some ls trannys are the same. If it has a s80 on the vin. Some rs and gs are different with the 4.2 gear.
But the gsr and type r have the same bolt holes.
b16, ls, gs, rs have different the same holes but different amount of teeth.
Old Nov 26, 2004 | 07:14 PM
microsoft_sux's Avatar
how hard is an LSD kit to install and how much do they cost? [post hijack!!!]
Old Nov 27, 2004 | 01:10 PM
stumpyf4's Avatar
My bad...
http://www.allmotorhonda.com/t...s.htm
Old Dec 1, 2004 | 05:35 AM
dester223's Avatar
Want to sell that SI LSD? I'm interested
Old Dec 1, 2004 | 07:40 AM
sleevedgsr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cluelessmale &raquo;</TD></TR><TR><TD CLASS="quote">I order the wrong LSD I got the Si tranny one and not the GSR one. From what I read so far both trans have a 4.4 FD. Can I just use a Si ring gear?</TD></TR></TABLE>
You can't use the same si and gsr are totally different. Si has 4.4FD but gsr is different! 95 teg gsr here!
Old Dec 1, 2004 | 09:45 AM
Default Re: si lsd w/ gsr tranny (boosted95teg)
It does fix and line up, I got a Si ring gear now I just need to get the right spacers
billabongrob
Transmission & Drivetrain
Nov 5, 2015 11:30 AM
B20 EK
Aug 8, 2004 08:26 PM
PainfulTeg
Mar 24, 2003 04:20 PM
cursED
Dec 31, 2002 07:59 PM
