p28 vs p08
Old Nov 25, 2004 | 11:00 AM
PHILLIPDEEZ's Avatar
Default p28 vs p08
which is a better ECU for a jdm D15B swap a p28 or a p08 cause i hear good thinks about the p28 but all d15 swap i see they have a p08 swap.
Old Nov 25, 2004 | 04:19 PM
NewBorn_EG's Avatar
Default Re: p28 vs p08 (PHILLIPDEEZ)
p08 cause its ment for it ..and this is why.....
dremmel
418 posts [100%]
EastSide Diego ca
3-17-2003
im suprised your not throwing a code. Im using the jdm IM and there was no nipple or vacuum source for the purge vap solenoid. so i did like the other guy and T'd off the fuel pressure regulator.Im not sure if this the greatest thing as far as vacuum pressure goes. I believe VP affects your miles per gallon. I may just have to restrict my air flowing in by going to a cheap DX intake manifold w/EX throttle body port matched. I'll do this because the US DX im has a vac source for the purge thingy. Also, from my swap experience D15B into VX using an EX harness and P28 ecu, I had to rig a throttle cable bracket. the VX throttle cable bracket doesn't mount on both bolt holes for the JDM IM. Probly best if i just get a Ex/Si throttle cable to mount how its supposed to. The other thing i had trouble with is that since im stuck with my VX exhaust manifold for now... I had to add 6-8" of extra wire to my o2 plug(4wire which goes with EX harness & P28 ecu).
Overall i LUV my swap I think the clutch shop got a lil happy lightening my flywheel -3 pounds... & my 6puck ceramic disc . It accelerates like it wants to spool for turbo! I went up to a DX tranny since i really hated the tall gears in the VX (relisting on egay). With a aluminum intake and GREENmonsterfoam HKS filter... dang it howls and hollers! oh, use the VX timing belt & H20 pump for replacing the unknown miles jdm ones.
Old Nov 25, 2004 | 05:09 PM
DJ_SaNdOz's Avatar
P28 works fine, it just runs rich. I'm running a P28 on my D15B. My ECU is chipped, and I tried a stock P08 program, but I get a solid CEL, so I need to see what the deal is when I get a chip burner. I wish it worked so I could tell you the difference, but I can say that the P28 works fine....
Old Nov 25, 2004 | 08:06 PM
NineTwoSi's Avatar
run a p28 on my d15b and it works fine... no codes!
Old Nov 27, 2004 | 10:44 PM
Tad's Avatar
Tad
now i'm curious,
if you have a socketed/chipped ecu,
say.. a p08, and decide to run a p28 program.. does that make that ecu exactly like a p28? cuz the electronics inside do look different.. but it'd be running the same maps.
I wonder if they work the same.. hmm...
Old Nov 27, 2004 | 11:14 PM
Eddiebx's Avatar
you will most likely throw a code if u try to run a p28 program on a p08 simply becuase the p28 will look for a heated o2s, and the p08 board is not equipped with a heated o2s, they run one wire o2s
Old Nov 29, 2004 | 11:29 AM
DJ_SaNdOz's Avatar
Default Re: (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">you will most likely throw a code if u try to run a p28 program on a p08 simply becuase the p28 will look for a heated o2s, and the p08 board is not equipped with a heated o2s, they run one wire o2s</TD></TR></TABLE>
Uberdata allows you to turn functions on & off, i.e. o2 heaters, knock sensors, etc. So, as long as the person chipping the ECU knows what they are doing that shouldn't be an issue....
baromeo
Dec 20, 2009 06:49 PM
ejoner
17
May 18, 2008 11:42 PM
DCxMagus
Aug 11, 2007 05:02 PM
Emshhh
Sep 26, 2004 05:45 PM
