Drive axle nut
Old Nov 25, 2004 | 10:09 AM
jagged4698's Avatar
Default Drive axle nut
I can't get the drive axle nut off...anyone have any suggestions?
Old Nov 25, 2004 | 11:57 AM
EX-JAY's Avatar
Default Re: Drive axle nut (jagged4698)
Impact gun, or get a breaker bar with a 8 feet pipe extension for more leverage. I tried using the breaker bar but it broke. So what I did was have my mechanic loosen the nut with an impact gun, then i tighten it to my own force and drove home like that to make my repairs. Hope this helps.
Old Nov 25, 2004 | 12:18 PM
slwh22accord's Avatar
Default Re: Drive axle nut (EX-JAY)
if you cant get ahold of an impact, try soaking it with wd 40, and heating it with a torch. It has always worked for me.
Old Nov 25, 2004 | 12:26 PM
brads94accord's Avatar
i used a breaker bar with a 4 foot pipe extension and the help on my roomate, we both pushed down on it.
Old Nov 25, 2004 | 02:14 PM
-Bionic-'s Avatar
Former Sponsor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-JAY &raquo;</TD></TR><TR><TD CLASS="quote">Impact gun, or get a breaker bar with a 8 feet pipe extension for more leverage. </TD></TR></TABLE>
Old Nov 25, 2004 | 04:17 PM
TOAB's Avatar
Default Re: Drive axle nut (-Bionic-)
go get a big impact... my car was dragged across my floor by a big fat mother ****** using a snapon breaker after i snapped 2 craftsman ones.
Old Nov 25, 2004 | 04:22 PM
jagged4698's Avatar
Default Re: Drive axle nut (TOAB)
so what yall are all saying is that this isnt going to be a pretty project....
Old Nov 25, 2004 | 04:48 PM
TOAB's Avatar
it should be easy as hell... but if those nuts are over torqued and sit for awhile it can be a pain in the ***. if you can drive to an autoshop and have them buzz it off with an impact, then put it back on and drive home. i had to do that this summer.
Old Nov 25, 2004 | 05:24 PM
yardy8301's Avatar
about 4 months ago i tried to remove my driver side axle nut with a breaker bad and about 5ft pipe. 4 months later i have 2 broken breaker bars, a new axle sitting in my garage, and still have a broken boot. yea, that little ****** wont just come of without a hell of a lot of elbow grease.
Old Nov 25, 2004 | 05:38 PM
TOAB's Avatar
IMPACT
Old Nov 25, 2004 | 05:47 PM
yardy8301's Avatar
yea i know. just fear that not working either, then im just fucked. soon ill get it done.
Old Nov 25, 2004 | 07:01 PM
srfnscubamunkey's Avatar
impact or a breaker bar with a long extension it will work make sure its a half inch drive or it will break remember to torqe it down to 181 ft pounds when your finished (if its a 5th gen)
Old Nov 26, 2004 | 01:47 AM
TOAB's Avatar
if that dont work cut it off.
replacement shafts come with new nuts...
Old Nov 26, 2004 | 08:48 AM
Stew Pidasso's Avatar
Default Re: (TOAB)
Be careful with the torch because if you get the axle too hot you can "boil" the grease out of the wheel bearings. A big impact works the best.
Old Nov 26, 2004 | 09:20 AM
dan1220's Avatar
Default Re: (Stew Pidasso)
i used a breaker bar with about 4ft of pipe, and sorta jumped on it...it seemed to work pretty good
Old Nov 26, 2004 | 09:24 AM
type-t's Avatar
Default Re: (dan1220)
i had to remove that nut this week and it was pretty easy...8 foot pole and a breaker bar....but make sure you torque to specs when you put it back together..goodluck..the 8 foot pole does the job
Old Nov 26, 2004 | 12:30 PM
Riceburner247's Avatar
Default Re: (type-t)
I use a Craftsman 18" 1/2 drive breaker bar with a 4' pipe over the breaker bar.
MI4$DC5
29
Mar 7, 2006 03:21 PM
fastlude69
Sep 23, 2005 02:34 PM
xSCTYGx
Jun 2, 2004 09:21 PM
deviant1
13
Oct 23, 2003 07:29 AM
2k1_ITR_0736
14
Jan 13, 2003 10:48 PM
