tried searching but didnt get much....how to fix defrost
Old Nov 25, 2004 | 09:38 AM
teg969's Avatar
Default tried searching but didnt get much....how to fix defrost
ok ive being going hi and low trying to figure out what the problem is with the defrot on the rear glass on my 88 SI crx...
at first the button wouldnt even light up...now i messed with it a bit and it does..but still no defrost action...
now my last resort is to use bandwith and ask you guys if you would have an idea on what to do to fix this...what should i look for...what to change etc..
THanks....here in Kanada we have cold weather and i cant see when the ice take over....or condensation
thx
Old Nov 25, 2004 | 11:19 AM
tur3oDC4's Avatar
Default Re: tried searching but didnt get much....how to fix defrost (teg969)
Bump ... is it grounded?
Old Nov 25, 2004 | 12:31 PM
teg969's Avatar
Default Re: tried searching but didnt get much....how to fix defrost (B18CRXjake)
thx for the answer....it might be i jsut noticed a cut in the wires...but not sure if there part of it
Old Nov 25, 2004 | 01:02 PM
tur3oDC4's Avatar
If theres a cut in the wires .... im pretty sure thats the problem lol
Old Nov 25, 2004 | 06:20 PM
teg969's Avatar
dam i checked and nothing is happening
this is kinda shitty...can you actually change something in the back windshield with out changing the hole hatch?
Old Nov 25, 2004 | 06:44 PM
eda6's Avatar
Try this and report back. Get a voltmeter
Look in the lower corners of rear window. + terminal is on the drivers side and - is on the passenger side. See if there's 12V from + to ground. If not the defogger relay is bad or there's an open in the wiring.
If you have 12V check continuity between - terminal and ground. If no continuity check the defogger ground wire.
Once you figure out what happened you can test each heat strip. Put + lead in middle of heat strip and - lead to ground. If you have 6V the heat strip is broken on the - side from the center. If you have 0V the heat strip is broken on the + side from the center.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teg969 &raquo;</TD></TR><TR><TD CLASS="quote">thx for the answer....it might be i jsut noticed a cut in the wires...but not sure if there part of it</TD></TR></TABLE>
got a pic of the cut wire?
Old Nov 26, 2004 | 03:24 AM
teg969's Avatar
Default Re: tried searching but didnt get much....how to fix defrost (eda6)
wow thx alot i will check that a soon as possible...
unfortunatly no pics...but the cut is right up where the hatch onpens and closes near the roof....the plastic surrunding a few wires is cut...
thx
Old Nov 26, 2004 | 04:44 AM
crx_88_si's Avatar
i had a similar problem on a different car. the light would come on but nothing would work out back. If you look at the window the terminals for the defogger are soldered onto the window. the solder on mine broke and was off SLIGHTLY. hardly noticable but closer inspection revealed the culprit! I soldered her back on and works since. check that.
Old Nov 29, 2004 | 05:27 AM
teg969's Avatar
Default Re: (crx_88_si)
dam i got shitfaced so bad on the weekend didnt have to time to even check the car.....ill let you guys know ASAP
Old Nov 29, 2004 | 08:14 AM
user 98292739's Avatar
i had the same problem with my 91 si. my button didnt light up and it did. but still no defrost. so i bought a new button of ebay for 6 bucks put it in and it works great now. so you might just need a new button if yours was out.
Old Nov 29, 2004 | 11:30 AM
teg969's Avatar
Default Re: (locovirus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by locovirus &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem with my 91 si. my button didnt light up and it did. but still no defrost. so i bought a new button of ebay for 6 bucks put it in and it works great now. so you might just need a new button if yours was out. </TD></TR></TABLE>
you mean your button worked, then didnt work, then worked but you still had no defrost...you got a new button and everything is fine?
austinramsay
Aug 3, 2014 11:24 AM
austinramsay
Aug 3, 2014 11:22 AM
y2kferari
Apr 4, 2010 12:32 AM
schueytenten
Jul 10, 2007 03:36 AM
2ndGenREX
Dec 28, 2004 03:51 PM
