Prelude 01 Valve Adjustment
Old Nov 25, 2004 | 04:32 AM
rpatel2369's Avatar
Default Prelude 01 Valve Adjustment
Is it typical for 01 prelude with 45000 miles to need valve adjustments?
I hear a ticking sound and at higher rpm's it more noticeable.
Thanks in advance.
Old Nov 25, 2004 | 04:55 AM
ludegetsmwet's Avatar
Default Re: Prelude 01 Valve Adjustment (rpatel2369)
it depends on how hard the engine has been beat on. If you have some mechanic skills take of the head and see what's going on and then if you can't do the work yourself at least you know what is going on with the valvetrain.
Old Nov 25, 2004 | 05:33 AM
OTT's Avatar
OTT
Default Re: Prelude 01 Valve Adjustment (ludegetsmwet)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludegetsmwet &raquo;</TD></TR><TR><TD CLASS="quote">it depends on how hard the engine has been beat on. If you have some mechanic skills take of the head and see what's going on and then if you can't do the work yourself at least you know what is going on with the valvetrain.</TD></TR></TABLE>
Thats a stupid post
Don't take your head off if you dont know what your doing/dont have the correct tools. Besides that you only need to take off the cam cover to inspect the valvetrain, just looking at it wont tell you jack.
You don't have to adjust them but you could check each one with a set of feeler guages and see whether they're in spec or not.
You'll still need a torque wrench for re-assembly.
Shakes did a good guide on valve lash adjustment, you should look in the Prelude links
Old Nov 25, 2004 | 08:09 AM
CFLude97's Avatar
Default Re: Prelude 01 Valve Adjustment (OTT)
i just had mine done..had 72,000 miles on the car..the valves started to get louder and louder so i had them adjusted..there not silent or anything but it sounds 10x's better than it did.if i were you i would do it..
Old Nov 25, 2004 | 09:32 AM
OTT's Avatar
OTT
with the valves set correctly there wont be much noise, the noise you hear most oif the time will be worn Lost Motion Asssemblies.
1speddy
Dec 10, 2007 03:26 PM
teamvirus
10
Oct 22, 2006 07:30 PM
ludesleep
11
Dec 11, 2004 03:36 PM
tremor86
Oct 22, 2004 10:39 AM
