RCA hi-low converter
Old Nov 24, 2004 | 11:17 PM
dj626's Avatar
Default RCA hi-low converter
I bought a hi low converter to hook up my amp to my stock deck, but I am having trouble finding the wires I need to splice into. I know I can go directly into the rear speakers on the deck lid, but does anyone know which ones?
The speakers both have an orange and a blue, and then a black and a red.
I need
L+
L-
R+
R-
- there is also a brown which is labeled common ground
Modified by dj626 at 12:51 AM 11/25/2004
Old Nov 25, 2004 | 07:23 AM
fcm's Avatar
fcm
Old Fart
Default Re: RCA hi-low converter (dj626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj626 &raquo;</TD></TR><TR><TD CLASS="quote">I bought a hi low converter to hook up my amp to my stock deck, but I am having trouble finding the wires I need to splice into. I know I can go directly into the rear speakers on the deck lid, but does anyone know which ones?
I need
L+
L-
R+
R-
Modified by dj626 at 12:51 AM 11/25/2004</TD></TR></TABLE>More info, MMY of car, it sounds like you have an amped or a "feedback" system, you are better off installing "LOC" at the HU , you can go to http://www.installdr.com to get color codes 94
Old Nov 25, 2004 | 11:20 AM
dj626's Avatar
Default Re: RCA hi-low converter (fcm)
The car is a 1999 honda prelude SH, and yes it does have the feed back system. What is the difference from the SLOC from the LOC?
Old Nov 25, 2004 | 05:21 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dj626 &raquo;</TD></TR><TR><TD CLASS="quote">The car is a 1999 honda prelude SH, and yes it does have the feed back system. What is the difference from the SLOC from the LOC?</TD></TR></TABLE> Probably the same thing, [leval output converter] also called SDC, [step down converter] or LLC, [line level converter], a lot of amps now have them built in, called, [ speaker input ] if all you need to do is add a sub, and you don't have the amp yet, get one that has "speaker input", as for wire color, I'm not sure, but if you disconnect one set and the speaker keeps working, its the set that is still plugged in, and if the speaker stops working, its the set you unplugged. 94
Old Nov 25, 2004 | 11:58 PM
dj626's Avatar
Must have something to do with the acoustic feedback system.
I figured out which wires to use and the sub still doesn't work, just a buzzing/drone noise. When I plugged another player in via rca, the sub works fine. So it's got to be either the converter or the feedback system. Anyone who has used a hi low converter in a 5th gen lude, any input is appreciated.
jonaldjenkins
Honda S2000
Apr 9, 2008 12:11 PM
tamadrumr88
Audio / Security / Video
Jun 1, 2005 08:59 PM
BoOsTiN Dc2
11
Mar 2, 2005 12:45 PM
azndragon328
Jul 14, 2004 07:22 PM
Jx3069
Sep 24, 2003 03:09 PM
