can i run jun IIIs with my comp
Old Nov 24, 2004 | 09:18 PM
96tegls's Avatar
Default can i run jun IIIs with my comp
i was searching around and i was wondering is ok to run jun III cams with about 11:0:1 compression or not. if you guys could answer that it will help me out thanks
Old Nov 24, 2004 | 09:22 PM
itralex's Avatar
Default Re: can i run jun IIIs with my comp (96tegls)
yeup, you can run them
but don't expect huge gains unless you have 12.0+cr
Old Nov 24, 2004 | 09:28 PM
96tegls's Avatar
welll my friend has a type r with them and i fell in love his compression is 12:2:1 but what other cam do you think will give big gain and sound that mean
Old Nov 24, 2004 | 09:40 PM
itralex's Avatar
Default Re: (96tegls)
i'm gonna go out on a limb and say
BC 3's, Rocket M22's, Toda B's, Jun 2's
Old Nov 24, 2004 | 10:16 PM
96tegls's Avatar
anyone run jun IIs i cant find much on them
Old Nov 24, 2004 | 11:58 PM
civicsirplus's Avatar
i run Jun 3s in my JDM ITR. Runs good. Using 2 ply Spoon head gasket to bump up compression a bit. Havent got measured numbers but i estimate my compression to be about 11.6:1. Im pulling 146kw on a hub dyno.
Old Nov 26, 2004 | 09:37 AM
555R's Avatar
yes you can run 11.0 comp but they love more compression
I run 12.5 maybe slightly more with the 10 thou mill i had to do
it just doesnt run very well on pump gas
but then again we have 94 and 100 at the pump here so im ok
Old Dec 2, 2004 | 05:49 PM
96tegls's Avatar
so any suggestions
Old Dec 2, 2004 | 07:08 PM
555R's Avatar
well you asked if you can run those cams with your setup...
however for best performance they work best with higher compressions
but when running more than 11.0 11.5 it gets tougher to run pump gas...
i am ok since we have 94 and 100 at the pumps...
Speed Infliction
Apr 23, 2006 03:13 PM
eh294
Aug 15, 2003 09:15 PM
BoM
Sep 14, 2002 08:28 AM
ahead
Aug 24, 2002 12:55 PM
AllMotorITR
Feb 7, 2002 09:55 PM
