changed distributor cap and rotor button now it wont start....
Old Nov 24, 2004 | 08:25 PM
oblique's Avatar
Default changed distributor cap and rotor button now it wont start....
95 GS-R timing had been a little off before i changed said items, also changedout plugs and plug wires, now it wontstart anyone with incite please help. thanks in advance
Old Nov 24, 2004 | 08:46 PM
timmy8151's Avatar
Default Re: changed distributor cap and rotor button now it wont start.... (oblique)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oblique &raquo;</TD></TR><TR><TD CLASS="quote">95 GS-R timing had been a little off before i changed said items, also changedout plugs and plug wires, now it wontstart anyone with incite please help. thanks in advance </TD></TR></TABLE>
Check your ignition coil, same thing happened to me after changing my cap & rotor. You're going to need an ohm meter and check the resistance across the primary and secondary connections.
Old Nov 24, 2004 | 08:47 PM
sabotage7's Avatar
are you sure that you put the wires in the right order on the cap?
Old Nov 25, 2004 | 12:07 AM
rovigian's Avatar
Default Re: changed distributor cap and rotor button now it wont start.... (timmy8151)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timmy8151 &raquo;</TD></TR><TR><TD CLASS="quote">
What is the ignition coil, I think mine may have went bad too.
Old Nov 25, 2004 | 11:27 PM
{Mineral Grey} ITR's Avatar
Default Re: changed distributor cap and rotor button now it wont start.... (rovigian)
Just swap out a buddy's distributor of the same motor. It it works it is definitely your coil.....
DjBij099
Oct 27, 2006 02:03 AM
sodacan33
Jun 17, 2004 06:53 PM
9deuce9rr
Feb 11, 2004 02:49 PM
Bspec18
Aug 1, 2003 09:56 PM
allmtr
Jul 10, 2003 02:40 PM
