Engine building advice needed
Well im building a Y7/y8 sohc, and i need some advice, me and my friends took my block apart, and saw that the bottom end was really dark smelled bad, (high milage motor) its getting hot tanked and honed so its all good.
I dont knwo what i should replace.
ive got a brand new:
headgasket
timing belt
main, rod, thrust bearings,
z6 rods, and pistons
Things im getting:
Clutch and flywheel
piston rings
all gaskets and misc items
Things im not to sure about??
Oil pump and water pump
I know i should while its out but im pretty much broke!!
headgasket
timing belt
Things im getting:
Clutch and flywheel
piston rings
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You're definatley going to want to replace the oil pump and water pump.
For sure!
Phil
</TD></TR></TABLE>For sure!
Phil
know nothing about your motor but have built many "hi-po" engines, may also want to have the block magna-fluxed, this checks for mircoscopic hole, cracks, as well as the crank, this is cheap insurance. if you have a crak or hole that is not visable you just wasted $$$$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "90acclude" »</TD></TR><TR><TD CLASS="quote">know nothing about your motor but have built many "hi-po" engines, may also want to have the block magna-fluxed, this checks for mircoscopic hole, cracks, as well as the crank, this is cheap insurance. if you have a crak or hole that is not visable you just wasted $$$$$
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You're definatley going to want to replace the oil pump and water pump. </TD></TR></TABLE>
good advice
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic »</TD></TR><TR><TD CLASS="quote">You're definatley going to want to replace the oil pump and water pump. </TD></TR></TABLE>
good advice
Ok well i guess ill go ahead and replace it, but ive heard that the Y series have weak oil pumps, should i go ahead and put a z6 pump on and change the pan?
I plan on boosting this motor, and i really dont want to have problems with it.
thanks for the help
thanks for the help
Eric W
Aug 8, 2011 07:40 AM
Pfieff
Dec 10, 2003 08:14 PM
