SAFC or VAFC for D16a6
Im turboing my 88 crx si and am going to run a afc hack. I might go with a zc or y8 later ... so what would you guys suggest. Getting a SAFC or VAFC? I know you can just not use the vtec wire .. any downfalls with that? thanks
Hey thanks, it looks like you have the same set up as me. mine isnt in yet, all i need left is a vafc/safc and charge piping. Is there any disadvantages while using a vafc? And, with the vafc do i need to run larger injectors, Im only going to run 6 lbs of boost and i have a 255 fuel pump.
I was told that there was no reason to use bigger injectors with a afc. ... reason being that i could just run 100% fuel threw my injectors. Thats wrong?
Again, would you go with vafc or safc, any other oppinions? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18CRXjake »</TD></TR><TR><TD CLASS="quote">I was told that there was no reason to use bigger injectors with a afc. ... reason being that i could just run 100% fuel threw my injectors. Thats wrong?
Again, would you go with vafc or safc, any other oppinions? thanks</TD></TR></TABLE>
You were told wrong. Get soem DSM 450cc injectors if your going to be using the AFC. Get the safc also, no need for the vafc. I wouldn't go with either though, the AFC has had it's time... it's old school. I recommend looking into chipping your ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quik sol »</TD></TR><TR><TD CLASS="quote">any afc = crap imo, dont scimp on fuel management.</TD></TR></TABLE>
turboedit
turboedit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis »</TD></TR><TR><TD CLASS="quote">Get a QAFC</TD></TR></TABLE>
Naah..thats old school man...Go with the stand alone atari just came out with..
Comes with donkey kong!!!
