Is it easy to ruin a distributer?
Old Nov 24, 2004 | 02:37 PM
rovigian's Avatar
Default Is it easy to ruin a distributer?
I compression tested my car. Everything was fine, put the plugs back in, and it won't start.
-Turns over
-There is fuel delivery
-There is no spark
I suspect the distibuter, is this how I test it, by looking for a spark to ground?
It just seems odd how I could have messed up the distributer just by dry cranking multiple times to do the test.. What else could cause sudden no spark?
Old Nov 24, 2004 | 04:25 PM
Tmack's Avatar
Default Re: Is it easy to ruin a distributer? (rovigian)
blew up your ignitor maybe
Old Nov 24, 2004 | 04:53 PM
rovigian's Avatar
It has 125k miles on it, so it's possible it went out. It's just odd that it would go out during a compression test, that's why I don't know what the problem could be.
Old Nov 24, 2004 | 06:05 PM
Dan GSR's Avatar
use a better ground, that intake is probably pretty well insulated
Old Nov 24, 2004 | 06:56 PM
Mikey's Avatar
Default Re: Is it easy to ruin a distributer? (Dan GSR)
Test the ignition control module by ohming out the primary and secondary coils. I don't know the resistance values off hand, but I'm sure someone on here could get those specs for you. If one of the coils has an open, you will not get spark.
Good luck and by the way, a new ICM is around 70-100 bucks.
Old Nov 25, 2004 | 12:24 AM
rovigian's Avatar
Default Re: Is it easy to ruin a distributer? (Mikey)
I have a volt meter, but are the primart and secondary coils, do I need to take off the other plastic cover to get to them?
Old Nov 25, 2004 | 05:39 AM
TurBoTeG's Avatar
yes, theres a screw holding the rotor on...take the rotor off and the plastic piece should pull off and youll have full access to the coil
Old Nov 26, 2004 | 10:51 PM
rovigian's Avatar
UPDATE: I wanted to let everyone know that doing the compression test did infact make the ignition coil in the distributer go bad.
It must have been because there was no load on it. But I had a distributer off of a newer LS that I grabbed the coil out of . It's good to have parts around.
Thanks for your help everyone.
Old Nov 27, 2004 | 01:10 AM
SlipAngleX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rovigian &raquo;</TD></TR><TR><TD CLASS="quote">UPDATE: I wanted to let everyone know that doing the compression test did infact make the ignition coil in the distributer go bad.
Thanks for your help everyone.</TD></TR></TABLE>
so how did you come to that conclusion? maybe it was because you broke something in the dist. itself?
Glad you got it fixed
Old Nov 27, 2004 | 01:34 AM
Sack Master's Avatar
Default Re: Is it easy to ruin a distributer? (SlipAngleX)
I've seen plenty of coils go out simply by cranking the engine over without spark plug wires or just not hooked up to the plugs. Don't know why. Never really bothered to research it. I figure the spark must need to be grounded.
As for your way of checking the coil. If you don't mind having someone crank the car over while 30,000 volts go through you then be my guest. Of course you should put your hand on the metal part of the screw driver and stand in water to really increase the affect. It won't be one spark. It will be a series of multiple sparks. And trust me its a real pleasant feeling
Old Nov 27, 2004 | 07:48 AM
JustinG60's Avatar
Default Re: Is it easy to ruin a distributer? (Sack Master)
when you check for spark it is considered well, i would say, safer to pull a spark plug out and then put it back in the spark plug wire and ground the plug and check for spark...
jdm_sai
18
Feb 16, 2010 05:19 AM
Bngo731
Jun 5, 2006 02:42 PM
tpr
Sep 13, 2005 09:00 AM
jt1583
Jun 19, 2005 03:59 AM
J-g-D-s-M-r
Sep 29, 2003 02:32 AM
