civic gx internals in d16z6
Old Nov 24, 2004 | 07:37 AM
bluebird's Avatar
Default civic hx internals in d16z6
Did a search and came up empty handed! I have heard that these civics which are powered by natural gas come with forged pistons and shot peened rods from the factory... Has anyone used these on a sohc vtec? My friend is going to turbocharge his sohc vtec so I figured that would be the best route to take IE factory forged parts. Plus I can get them pretty cheap!! Any information is a appreciated. Thanks
Old Nov 24, 2004 | 07:45 AM
klungemonger's Avatar
That is not the HX model, the CNG-powered Civic is called the GX. Don't know if they are forged for real though, but there has been discussion on them on the web, do a google search or something. I don't know though, I seem to remember it being discussed that they were hi-compression so that would not be good for the turbo...
Old Nov 24, 2004 | 07:48 AM
bluebird's Avatar
Default Re: (klungemonger)
OOOppps... Did I put Hx ? My bad I meant GX!!!
Old Nov 24, 2004 | 09:58 AM
gftgrill's Avatar
Default Re: (bluebird)
DO NOT use GX pistons with a turbo. the GX has really high compression which is bad for a turbo. I believe that the rods are the same as any other d of the same production model. The GX pistons would get good if you're going NA.
just tell your friend to save up for some eagle rods and a set of lower compression pistons.
HFXCIVIC
Jan 24, 2013 05:47 PM
Jun 20, 2004 04:53 PM
dynomax27
Jul 6, 2003 02:55 PM
spun Vtec
25
Dec 21, 2002 05:46 AM
Kail18
Nov 25, 2002 10:09 AM
