turbo mani - help
What the hell are you guys talking about?
The EX manifold as far as I know is almost like a header.
the CX and HF manifolds are the ones you would need for a turbo manifold. A company on homemadeturbo.com makes adapter plates.
BTW, I have a spare HF if you need it...
whats the big difference between using the EX over the CX of HF?
And yes.. your right.
The EX is like a header on 99 and 00, but before that they were cast manifolds and the one I have is off a 95.
NO dude,
all those people saying yes are probly just thinking you want to use it as a normal header.
the ex manifold wont work because it is a 4-2-1 setup, it turns into 2pipes, that won't work well at all to run into a turbo. also it hangs down super low compared to the cx/hf
the cx/hf is used alot because it's really short and stubby, and all 4 tubes run into one outlet that happens to be a good size to hook a turbo up to.
reason for this is it's built to have a cat sitting right up against it, while the ex's cat sits further down along the exhuast path.
correct... ex and si manifold(s) is pretty much a 4-2-1 header... the only one that can be used as a turbo manifold with a t3 addptr. plate would be the ones that have the cat on them.. if im not mistaken it would be hf, hx, and cx...
z6
Welding / Fabrication
Oct 20, 2005 08:37 AM
