00 civic si, Horrible high pitch howl coming from pass side engine bay.
Old Nov 23, 2004 | 06:20 PM
TommyTom83's Avatar
Default 00 civic si, Horrible high pitch howl coming from pass side engine bay.
at first i thought maybe the filter on cai was loose and it was causing a leak, then i thought maybe the bypass wasnt on square so i finally made the intake into a short ram and the noise is just getting louder. it only makes the noise when i come from a dead stop. its the worse noise in the world.... so friggn loud, any opinions would be grateful
Old Nov 23, 2004 | 07:29 PM
Redline96LX's Avatar
* B A N N E D *
Default Re: 00 civic si, Horrible high pitch howl coming from pass side engine bay. (TommyTom83)
brakes? check for lineal runout remember .0003 in.
Old Nov 23, 2004 | 07:39 PM
TekSI's Avatar
Default Re: 00 civic si, Horrible high pitch howl coming from pass side engine bay. (Redline96LX)
alot of intakes make this noise, i believe it's from the butterfly valve on the TB. my civic doens't make it, but my g/f's accord does, and she has the stock f22a4 with short ram, header, and exhaust
got louder after header was installed...annoying as hell
Old Nov 23, 2004 | 07:48 PM
TommyTom83's Avatar
Default Re: 00 civic si, Horrible high pitch howl coming from pass side engine bay. (TekSI)
hmm whats weird is ive had the header on for 2 months but now all the sudden this past week it started making this god awful noise... only thing i can think is its gettn cold here in chicago
Old Nov 23, 2004 | 07:56 PM
lohatch's Avatar
damn its loving the cold air huh
Old Nov 23, 2004 | 08:09 PM
krazn's Avatar
Default Re: 00 civic si, Horrible high pitch howl coming from pass side engine bay. (lohatch)
i wouldn't worry bout it....
if its really unbearable...can you put it back to stock and see what happens?
Old Nov 23, 2004 | 08:14 PM
TekSI's Avatar
Default Re: 00 civic si, Horrible high pitch howl coming from pass side engine bay. (krazn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazn &raquo;</TD></TR><TR><TD CLASS="quote">i wouldn't worry bout it....
if its really unbearable...can you put it back to stock and see what happens?</TD></TR></TABLE>
yea, if you wanna take the easy way out
tho i guess a stock intake with a K&N filter, inbumper baffles removed, would probably yield better gains than a short ram
HeresOtis
Dec 12, 2016 02:27 PM
crazy4carz
Aug 28, 2007 05:29 PM
Baron55
Nov 26, 2005 09:41 AM
dsadas89das78934
20
Jun 3, 2004 01:24 PM
