huge problem with rear strut/spring!!
Old Nov 23, 2004 | 05:11 PM
itrhopeful's Avatar
Default huge problem with rear strut/spring!!
so i go to install the springs i've been carrying in the car for like two years and we get the fronts changed out and start on the rear springs, but we can't get the strut off of the spring. they wer compressed and all but we couldn't get the nut broken off of the post. anybody got some ideas as to how this could be done? preferably without causing the need for a new strut?
if neccesary i'll get a new strut but only if i absolutely have to.
Old Nov 23, 2004 | 07:04 PM
mmuller's Avatar
Mad Scientist
Default Re: huge problem with rear strut/spring!! (itrhopeful)
what, the shaft is turning with the nut?
use an allen head in the shaft to hold it still while you unscrew the nut.use wd40 too
Old Nov 27, 2004 | 07:16 PM
itrhopeful's Avatar
Default Re: huge problem with rear strut/spring!! (mmuller)
tried the allen head but got kinda carried away and ended up rounding out the shaft. any suggestions for what to do with that? i was thinkin if i covered the threads with a length of hose an held the shaft with some vise-grips i might be able to break it loose enough to get it the rest of the way like you're supposed too. would that work do you think?
Old Nov 27, 2004 | 08:00 PM
drdisco69's Avatar
Have you tried an impact gun?
Old Nov 29, 2004 | 10:42 AM
wootcivic's Avatar
You CAN use a nice set of pliers to hold the shaft from turning, but you will need a new strut beacuse it will mess it up real bad... It's the easy way, not the correct way.
Old Nov 29, 2004 | 11:07 AM
timmy8151's Avatar
Default Re: huge problem with rear strut/spring!! (wootcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wootcivic &raquo;</TD></TR><TR><TD CLASS="quote">You CAN use a nice set of pliers to hold the shaft from turning, but you will need a new strut beacuse it will mess it up real bad... It's the easy way, not the correct way. </TD></TR></TABLE>
Yeah I had to use a pair of vice grips to hold the shaft one time, in order to take off the spring.
Old Nov 29, 2004 | 01:17 PM
itrhopeful's Avatar
Default Re: huge problem with rear strut/spring!! (drdisco69)
tried the impact wrench. still no go. i really don't feel like buying new struts and i def need a camber correction kit. any suggestions? i guess i'll try the pliers and covering the threads with some hose.
byrne_06
Jun 29, 2011 10:29 AM
hannslebo
Mar 28, 2009 11:12 AM
illios
Suspension & Brakes
Apr 25, 2007 08:16 AM
GroundZer0
28
Jul 30, 2003 04:13 PM
animated_life
Jan 3, 2003 10:49 AM
