Shaky wheel.
Old Nov 23, 2004 | 04:48 PM
shortyz's Avatar
Default Shaky wheel.
man i am stumped on this problem, usually its rotors warped. when i brake the wheel does a hardcore shaky, and when i stop its like the pads are breaking harder in one spot. what the **** is going on?
also when i move the wheel back and forth really quick i hear this CLACK CLACK CLACK noise.
i have.
1. replace rotors/pads
2. Replaced right front caliper
3. New right front axle.
Old Nov 23, 2004 | 05:06 PM
Skunk.Werks's Avatar
Default Re: Shaky wheel. (shortyz)
Maybe something related to the steering components like the rack possibly.
Old Nov 23, 2004 | 05:12 PM
NikoZai's Avatar
Default Re: Shaky wheel. (Skunk.Werkz)
interesting.. usually thats rotor warpage yeah.
So you replaced an axle cuz it was blown.. could something wrong with the midshaft do that?
I wana know the answer too
Old Nov 23, 2004 | 05:26 PM
JapJunkie's Avatar
Default Re: Shaky wheel. (NikoZai)
Its the Wheels Bearings! I had the same problem.
Old Nov 23, 2004 | 05:44 PM
Burlyirishdude's Avatar
Default Re: Shaky wheel. (JapJunkie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JapJunkie &raquo;</TD></TR><TR><TD CLASS="quote"> Its the Wheels Bearings! I had the same problem. </TD></TR></TABLE>
Don't listen to anyone except this person.....Set your car down on the Ground and pull the wheel back and forth, if it moves or wiggles at the top and bottom...you gotta get your car off the ground, jack it up, pull the wheel hub assembly apart, go and have the hub pressed...which will rip the bearing apart anyway.....have a enw one greased and put in.....It's a pain in the ***.. But it will solve so many future problems.
Point in case: if you let the bearing go to ****.....it'll back your lug nuts off and you will not like the outcome of that one.
i'm guessing no more then 100$ per side....70-90$ per bearing and 30$ for larbor.
Old Nov 23, 2004 | 05:52 PM
mamaboy's Avatar
check all suspension components and steering components. Tie rod, ball joints, wheel bearings etc. Best way to check most of these are pull and pushing on the component. Bearings should be noticeable especially when you spin the hub. Audible noise is usally associated with wheel bearing failure. removing the knuckle is going to be a pain in the ***. Those ball joints are hard to pull apart.
Old Nov 23, 2004 | 08:10 PM
shortyz's Avatar
Default Re: Shaky wheel. (mamaboy)
****, can i just goto the scrayard and buy a good one?
it would be cheaper.
Old Nov 23, 2004 | 08:14 PM
mr. carpenter's Avatar
you could go get a whole upright but being from a yard it's prone to go bad again or be bad to begin with.
Old Nov 26, 2004 | 09:44 AM
Default Re: Shaky wheel. (mr. carpenter)
try and find a crx si that has no front damage.....that's your best bet in getting a new hub assembly for cheap/decent price.
Legion_2
Mar 4, 2009 10:53 AM
Osek206
10
Oct 28, 2005 04:32 PM
vietboixstunnah
Sep 24, 2004 07:43 AM
Honda24C
11
Aug 3, 2004 08:04 PM
FD3S
Jul 25, 2004 06:46 PM
