anyone know anything about a code 45?
Old Dec 29, 2001 | 12:34 AM
rockwilda's Avatar
Default anyone know anything about a code 45?
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
current mods
CTR cams
skunk2 mani
AEM CAI
Spoon Headgasket.
any ideas? i just dropped the cams in yesterday
Old Dec 29, 2001 | 12:55 AM
Vtec integra's Avatar
Default Re: anyone know anything about a code 45? (da_rockwilda)
possibly o2 sensor
Old Dec 29, 2001 | 01:25 AM
B18C-EJ1
Guest
Posts: n/a
Did you get the MIL after installing the cams?
Old Dec 29, 2001 | 05:29 AM
rockwilda's Avatar
Default Re: anyone know anything about a code 45? (B18C-EJ1)
MIL? maintenence light? nope. everythng ran perfect until this went off.
Old Dec 29, 2001 | 07:21 PM
1fastGSR's Avatar
New User
my car throws a code 45 if I have too much valve overlap. What are your cam settings? I have also heard of people having the sme problem with S2 IM and ITR/CTR cams. Do you have a VAFC? It might be that all the extra air is creating a lean condition. You might need more fuel. Carboy has a wideband O2 sensor. Just buy a VAFC and have your car properly tuned. Thay do a good job. Don't forget to send me the dyno sheets!
Old Dec 29, 2001 | 07:27 PM
MachAF's Avatar
Causes of MIL 45:
Fuel Supply System
Primary o2 sensor
MAP senor
contaminated fuel
Valve clearance
Exhaust leakage
Being that you dropped in cams I'm going to guess that the valve clearnace is too loose or too tight.
Old Dec 29, 2001 | 11:50 PM
rockwilda's Avatar
Default Re: anyone know anything about a code 45? (1fastGSR)
cam settings are at 0,0
hmm, i had a valve adjustment when i dropped teh cams in. VAFC is comin soon. whatelse can be done to fix this.
is it okay to drive around? seemed like my fuel mpg dropped a little bit.
Old Dec 30, 2001 | 05:45 AM
1fastGSR's Avatar
New User
try resetting the ECU.
Old Dec 30, 2001 | 10:33 AM
rockwilda's Avatar
i did that earlier this morning (9am) before i went to work. everything seems fine so far. thanks for everyone's input.
1fastgsr - should dyno this suck pretty soon if everything comes out okay
Old Dec 30, 2001 | 11:52 AM
1fastGSR's Avatar
New User
let's see if you can beat my nunbers!! My number are with a Comptech 4-2-1 header, 2.25" cat and Comptech exhaust. I now have ITR JDM 4-1, 2.5" cat and 2.5" exhaust with ITR muffler (sleeper).
Old Jan 1, 2002 | 04:23 PM
rockwilda's Avatar
ok update my situation. i had reset the ECU a couple days back. it popped on new years eve night. this morning i went out to check the code, but it didn't pop back on.....strange . any ideas?
Old Jan 1, 2002 | 05:19 PM
1fastGSR's Avatar
New User
what code was it this time?
I really think you need to go have your car tuned on the dyno. If you are waiting to break in the cams, then do not worry about it because there is nothing you can do, except reset the ECU.
I would have also suggested to check the valve clearances but you already did a valve adj. so they should be OK. Have checked you ignition timing? It might be off.
Also check that the cams are indeed at TDC and it did not jump a tooth on the cam gear.
xxstuntin4life
Feb 3, 2009 04:33 PM
t . b o z
Jan 2, 2005 12:58 PM
vitegra
Apr 26, 2004 07:27 AM
Mr. 1582
Nov 7, 2003 03:32 PM
speedymon
Feb 4, 2003 03:28 AM
