b18 cam removal
Old Nov 23, 2004 | 01:41 PM
1992tegRS's Avatar
Default b18 cam removal
im parting out my old b18a motor dropped a JDM b16a in. iv taken off the valve cover and taken out all the screws but the cams ont budge. how should i take off the brackets holding the cams in place
Old Nov 23, 2004 | 01:57 PM
ian.'s Avatar
Default Re: b18 cam removal (1992tegRS)
wtf??
Old Nov 23, 2004 | 02:04 PM
B18OnTop's Avatar
Default Re: b18 cam removal (IC33)
whats the poll for?
Old Nov 23, 2004 | 02:10 PM
Chubz's Avatar
its obvious you dont know what your doing, so why bother.
Old Nov 23, 2004 | 02:56 PM
1992tegRS's Avatar
Default Re: b18 cam removal (Chubzilla)
obviously i dont know what im doing why would i ask a question 2 somthing i already know how 2 do? im parting it out cuz i got teh head built for a turbo and port an polished and its worth selling
Old Nov 23, 2004 | 03:07 PM
dick_213's Avatar
if the cam caps wont come loose try using a lead shot hammer. make sure its plastic and dont mix up the camshaft caps, they go in a certain order.
Old Nov 23, 2004 | 04:48 PM
boosted k20's Avatar
Default Re: b18 cam removal (dick_213)
u can also lift up on the cam gear itself once all the cam caps bolts are removed. this will break them loose. u can also use a screw driver to pry the cam up, but make sure u dont dent any part of the head.
Old Nov 23, 2004 | 05:12 PM
Tmack's Avatar
Default Re: b18 cam removal (boosted k20)
or put a wrench on the cam gear with the belt off and turn the cam back and forth just a little bit. This should break the seal.
Old Nov 23, 2004 | 07:03 PM
1992tegRS's Avatar
Default Re: b18 cam removal (Tmack)
thanx every1 for your input i got the cams out and tookoff the head and put the cams back in. not its ready for ebay
mouab18c1
15
May 6, 2011 11:22 PM
Po0r LiTTle CoUpe
Aug 3, 2006 08:16 PM
Brewer
Jan 13, 2004 10:58 AM
shingles
Dec 24, 2001 04:45 AM
